Samsung LN40B5ooP3FXZA Cycling on/Off
  • BruceGilbert
    • Apr 2020
    • 31
    Have a Samsung given to me. When power is applied backlights will come on and stay on for approximately 10 seconds then power off and then on once again. When looking at the back lights from the rear they appear to be flickering. Tried disconnecting the cable from the power supply to the main board when it powers up and there appears to be no flicker however display will only remain on for 3 seconds with the cable disconnected.. Tried disconnecting the TCONN board with no change. I suspect the main board BN94-02746Y.
    I am unable to purchase a repair kit for this board and replacement boards are out of the question. Has anyone had experience with this type of failure and is there a common failure point on this board that I could investigate.
    Thank you to everyone for your time to look at this post.
    • 12274
    • U.S.
    Re: Samsung LN40B5ooP3FXZA Cycling on/Off
    Usually if the backlights do not stay on with cable from powerboard to mainboard unhooked, you have a backlight or powerboard issue that must be corrected first.
    • Biruslapio
      • Nov 2013
      • 552
      • Brasil
      i've had two LN40B530 that would power on the CCFL, but after 3 seconds they would shut down and blink the red standby LED, disconnecting the main board from the power supoply should light all the lamps and not shut down.
      Solution: replaced some defective CCFL lamps. If it cycles the lamps on and off I don't know what could it be, possibly the PSU, but this series has notorious problems with lamps heating too much and failing.
      • zens electronics
        • Jan 2021
        • 31
        Might be worth checking the PFC volts on power supply .
        • BruceGilbert
          • Apr 2020
          • 31
          Thank you everyone for your input. I was leaning towards a bad main board. Just to be clear if I disconnect the connector to the main board the backlights should remain on? As previously stated I get about 10 seconds when connected but only about three seconds if I disconnect the cable to the main board as soon as the backlights are on. This is why I suspected the main board possibly not sending a return signal to the power board to remain on. Just my thoughts.
            • 12274
            • U.S.
            NOPE, reread post #2, meaning there's a problem with the backlights or powerboard, you might not even have a problem with the mainboard but there is for sure a problem before it as stated.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              I would also check the resistance of the inverter transformers and ensure they match each other.
              Is there any discolouration on the underside of the circuit board below any of the transformers.
              Are all the transformer solder joints sound.
                Show us good clear pictures of the whole backside of the TV showing all the boards and then straight shots pictures of each board will help.
                • BruceGilbert
                  • Apr 2020
                  • 31
                  Wow thank you so much for all your help. I believe I found the problem. Hopefully optimistic. I found that on assembly of the TV a screw that holds the back cover on the TV in the center went through the cable between the power supply module and the main board. I split the ribbon cable and repaired the wires and the TV has worked for a few hours now. If I get an opportunity I will take the recommended pictures for everyones reference perhaps on another TV or possibly this one if it fails again.
                    • 12274
                    • U.S.
                    Ok, strange tho that the backlight didn't stay on when cable from powerboard to mainboard was unplugged, pretty sure a recent LN40 I dealt with did stay on but maybe it wasn't a LN40B.
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • ohren
                      by ohren
                      09-08-2023, 05:24 PM
                    • C152Heavy
                      by C152Heavy
                      Summary for TL-DR readers:
                      • VCC pin (18) of PFC...
                      01-11-2023, 02:53 PM
                      09-07-2024, 05:50 AM
