SHARP LC-70UQ17U standby but no backlight or video =(
  • nomoresonys
    • 12330
    • U.S.
    Re: SHARP LC-70UQ17U standby but no backlight or video =(
    video there, most of them work in a similar manner, he's testing without dismantle at about the 5 minute mark, that test at 5 minutes do with tv unplugged, the tester will do the work: https://www.youtube.com/watch?v=Gkxm8jqqbQs
      You should also retest those Voltages you reported since there are so many errors as shown.
      • Diah
        • Feb 2013
        • 6574
        Originally posted by anthony_c
        I have the dreaded 2-5 blink code.
        which LED color you have the 2-5 blinking code ?? RED with GREEN or ONLY RED !!!!
        yours First post measurements all mysterious , maybe yours Digital meter battery low.. so .. post clear photos on yours power boards especially the socket label which goes to main boards.
        • anthony_c
          • Jul 2019
          • 49
          Ok, will follow and report back.
          • anthony_c
            • Jul 2019
            • 49
            Will do and report back @budm, its a bit hard being that the TV is so huge. I HAVE to test it with the board plugged into the TV right?
            • anthony_c
              • Jul 2019
              • 49
              Only blue, no other color. I will post clear photos for you tomorrow when I get back to the TV.
              • anthony_c
                • Jul 2019
                • 49
                Welp guys, I think I have bad news =(
                After spending so much time , I finally connected the backlight tester and it does seem that the panel is cracked. It was working fine while on the wall and sat in the same place since it was dropped of to me so I suppose it was cracked in transit. It makes sense because the guy said he wasnt getting any blinking only distorted picture when he took it off the wall.
                This sucks as I am pretty sure, originally this was a driver issue which I could have fixed by cutting out the tabs but now theres nothing that I can do =(
                Posting pictures shortly.
                • anthony_c
                  • Jul 2019
                  • 49
                  Here are the links to the images:
                  • anthony_c
                    • Jul 2019
                    • 49
                    If indeed the panel is cracked, is it worth stripping it down for anything? Or should I just dump it?
                    • mkdj
                      Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                      by mkdj
                      Dear all,
                      I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                      I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                      Both N-Channel Mosfets: nothing odd
                      P-Channel MOSFET number 1:
                      source - drain : 117 kOhm
                      source - gate: 96 Ohm
                      gate - drain: 117 kOhm
                      P-Channel MOSFET...
                      08-20-2025, 06:08 AM
                    • barry101
                      Apple 820-3662 VCore shorted to ground.
                      by barry101
                      Hi, Would appreciate some help.
                      I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                      Get charger light but no fan spin or chime. No liquid damage.
                      Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                      Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                      With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                      Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                      06-24-2025, 07:34 AM
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
                    • sefoster
                      Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                      by sefoster
                      I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                      11-20-2022, 09:29 AM
                    • gavenb
                      Sharp LC-80LE661U 80 inch
                      by gavenb
                      Hi folks!
                      I have a LC-80LE661U that had some interesting issues.
                      Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                      I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                      11-12-2023, 02:05 PM
