Weird blurry -no-picture on Plasma TC-P60S30
  • paulstef
    • Dec 2013
    • 724
    Hi
    This TV has no picture, or nothing that resembles a real picture, just some slowly changing blurry forms and pixels. It ends up having a jumping white square in the middle, presumably the "no source connected" message, I guess.
    Front LED turns on normal. Vsus is 209.8V. +15Vc is ok also.
    Power semiconductors on all boards tested, ok. SS and SC board LEDs are lit. (Tnpa5400 and Tnpa5399)
    I should mention the TV was extremely dusty when I got it.
    What else could I test?
  • paulstef
    • Dec 2013
    • 724
    Re: Weird blurry -no-picture on Plasma TC-P60S30
    Here another picture with the menu.
    • paulstef
      • Dec 2013
      • 724
      It's similar to the problem towards the end of this thread so might be a "panel problem"
      https://www.justanswer.com/tv-repair...not-power.html
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Check if any of the mounting screws on the ss and sc boards are loose.
        • mmartell
          • Oct 2013
          • 3189
          Look for the auto-gen jumpers on the control board to see the test patterns. I'd doubt you have a bad panel.
          • LITEZONER
            Panasonic TH-65PF9UK 65" plasma display weird issue
            by LITEZONER
            forgot to put the model number in the last post, could not edit it, guess I waited to long. anyway, has anyone seen this weird issue on one of these plasma sets, I was thinking maybe a loose ribbon, but wanted to check if anyone had seen this before. thank you...
            10-22-2021, 09:27 PM
          • Loki_Fido
            (Weird) BIOS info for HP Pavilion Aero 13-be1021AU
            by Loki_Fido
            Hi folks,
            This HP Pavilion Aero 13-be1021AU came to me for a repair. And it seems to have a weird BIOS chip. (Pic attached)
            I asked my CH341A to read it and doesn't even know what to do with this. We are both very confused.
            BIOS - XMC 25RU128CH10 (1.8v)
            What the heck is this? I looked all over the MB. This is the only bios.
            When I asked the NeoProgrammer to detect it, it just pops up an empty screen, and asked me to enter the bios number. And when I did, it doesn't do anything. NeoProgrammer showed me just this SPI ID: 204418. Don't know what...
            03-20-2025, 01:57 AM
          • ArMaaN376
            Samsung PS51E550 Plasma TV
            by ArMaaN376
            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
            Opened TV cover & observed foll
            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
            How to confirm Y -Buffer board...
            06-19-2024, 04:05 AM
            APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
            by sam_sam_sam
            This started a few days ago and does this about every 8 hours
            After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
            The battery backup is about 3 or 4 years old
            Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
            06-02-2024, 02:30 AM
          • jm1234
            Panasonic plasma TX-P42ST50 - 6 blinks
            by jm1234
            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
            I checked that board for any obvious faults...
            05-22-2024, 06:59 AM
