Sound and picture but no backlight
  • JCdes
    • Feb 2013
    • 91
    Model tv is RCA LED46C45RQ, mainboard is T.RSC8.78, power supply number is RE46HQ1004, also has RS126S-3T01 on it. I tested the led strips with the led tester and all of the leds light up.
    With the tv on stby I get 58v on all led+ connections, with the tv powered on I get 61v. I can't find a service manual so could it be the power supply led driver?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sound and picture but no backlight
    Can you post well focused pictures of your power supply. What is the power supply part number?
    You have two mosfets and two diodes close to the led connector socket. Have you checked them?
    • JCdes
      • Feb 2013
      • 91
      Here you go...
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        What is the voltage at BL_ON (CON4) and also between the two legs of EC101 (68uF capacitor)when in and then out of standby. What is the voltage printed on that capacitor.
        Can you post a photo of the underside of the power supply.
        • JCdes
          • Feb 2013
          • 91
          Stepped out of the house, I'll be back in about 2 hours with the info. I did measure all that but can't remember if bl on was 3.3 or 5 and ec101 was 375 but cant remember in which state I measured. It is rated at 450v.
          • JCdes
            • Feb 2013
            • 91
            I did notice ec101 discharging in about 2 seconds after power off.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Also what is the part number written on U200 on the underside of the board.
              When you tested the leds what voltage were they operating at.
              If you disconnect the leds can you check what Led+ and Led- voltages peaks at when you power on
              • JCdes
                • Feb 2013
                • 91
                I'm on my way back home, I'll check the part number as soon as I get there. Which leads are you referring to? If you mean the led leads they go up to 83v fully lit with the tester give or take from what I remember.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  With the led lead connector disconnected I'm interested in if the voltage peaks and then drops. You say 61V peak and then drops to 58V. Was that with the leds connected.
                  • JCdes
                    • Feb 2013
                    • 91
                    Yes connected and disconnected... Measured both header without leads and leads connected made no diff.
                    • JCdes
                      • Feb 2013
                      • 91
                      Trying to read that chip...
                      • JCdes
                        • Feb 2013
                        • 91
                        Ok LD7750RGR
                        • JCdes
                          • Feb 2013
                          • 91
                          Better look, got the pic from the web... High voltage pwm controller...
                          • JCdes
                            • Feb 2013
                            • 91
                            Traced pin1 on the pwm to pc2
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              I was looking to identify any Led Driver IC. The LD7750 is a PWM controller but it appears to be on the COLD side of the power supply which leaves me puzzled.
                              • JCdes
                                • Feb 2013
                                • 91
                                Its on the hot side, I traced it to the octocoupler "pc2" which is an EL817
                                • JCdes
                                  • Feb 2013
                                  • 91
                                  Sorry I messed up!!! I was looking at u102
                                  • JCdes
                                    • Feb 2013
                                    • 91
                                    U200 is marked e19359 0B3350CP
                                    • JCdes
                                      • Feb 2013
                                      • 91
                                      That's the led driver...
                                      • JCdes
                                        • Feb 2013
                                        • 91
                                        Here's what I found...
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • DKWS89
                                          Sony XBR 49x900E - Sound and backlight on but no picture
                                          by DKWS89
                                          Hey Guys,
                                          So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                          All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                          12-14-2023, 04:30 PM
