Sound and picture but no backlight
    Re: Sound and picture but no backlight
    Originally posted by JCdes
    I can do that tomorrow. I got all the tools and goodies in my hobby shack outside the house. I'll do it and report back tomorrow. I really appreciate all the help. Resistor to center leg and to chassis right?
    Yes, if you trace out the middle pin of that Transistor, you can see that goes directly to the LED connector where the White wire of the Cathode of the LED string is connected to.
      Post #7 are low res.
      So here are High res pix provided by shopjimmy: RCA RE46HQ1004 (RS126S-3T01) Power Supply for LED46C45RQ.
      Notes: SJ pix shows black bumpers that block out the traces, OP provided the pix in post 358 with bumper removed around the LED connector as I requested.
      • JCdes
        • Feb 2013
        • 91
        I got the resistor, 100ohm .5%, I'll do the test as soon as I get home from work. The led pinout from left to right is bottom led strip to top left strip in that specific order on both - and + led connections. Can I do the test using q206 instead of q201? I can see better if the string reacts since it's the bottom one and has big openings that let me take a better look if it flashes. I could add a momentary on switch also if that's ok.
          You can use any one of the LED - pin.
          • JCdes
            • Feb 2013
            • 91
            Sorry guys but I can't do the test today, still at work...
            • JCdes
              • Feb 2013
              • 91
              Merry christmas! Did the test but nothing happens. 10 seconds, led did not even flicker and resistor did not get hot.
              • JCdes
                • Feb 2013
                • 91
                I took a short video using the tester to light up the bottom led strip. This has nothing to do with the resistor test. Just a vid showing the voltage on the tester and led brightness.
                https://drive.google.com/file/d/1T9l...dvSE4UwKrX5HzL
                • JCdes
                  • Feb 2013
                  • 91
                  I took a chance and replaced EC201 and EC202 with brand new caps and nothing changed. Just in case I wrote down the Part#'s for Q220 is B649A, D6 is BYC10, Q215 is 18n20 and D200 is MBR10200F, D2 is MBR20150F.
                  While looking at D2 I noticed some kind of solder splatter on T1's cold side. Here's the pic. It might be nothing but just want to show you what I saw.
                  • JCdes
                    • Feb 2013
                    • 91
                    MBR10200 on D200 has continuity among the two external legs. I did not remove it just tested on board.
                      Q103, U102, T1 are part of the always on SMPS.
                      D2 is the rectifier for the always on 12V which is then fed to switched MOSFET Q2 to provide switched 12V output at the connector CON2 when PS-ON is present.
                      D1A//D1B are rectifier for the always on 5VSTBY, this 5v is fed to MOSFET Q1 to provide switched 5V output at the connector CON2 when PS-ON is present.
                      D6 is the rectifier for the always on 60V (filtered by EC11, 12) that is fed to the Boost converter (L201, Q215, D200, U200, EC201/202) that will produce about 100VDC when BL-ON is present.
                      L102, Q102, U101, D101 are for the PFC Booster Voltage which is also turns on when PS-ON is present.
                      At this point it looks like the Boost Voltage is not high enough, the LED string with the bypass resistor should have lit up for seconds.
                      So you should remove the D200 and check it in diode mode and in resistance mode in both directions but before doing that I need you to remove that 3-pin connector CON4, then put black probe on the chassis, red probe on any one of the LED + pin, with the TV turned off you should see about 60V, then turn on the TV and see how high the Voltage jumps up to.
                      • JCdes
                        • Feb 2013
                        • 91
                        Con4 unplugged check voltage on any +led while on stdby. Then check again with tv powered on and con4 unplugged still?
                        • JCdes
                          • Feb 2013
                          • 91
                          60.6v power off, 63.6v for a second when power on is pressed then back to 62v
                          • JCdes
                            • Feb 2013
                            • 91
                            Forgot to mention I had measured Q220 previously nothing unplugged... On stdby it has 60v, 0, 35v. Powered on 0.6, 0, 0.1
                              Yes.
                                That is with CON 4 not in place, correct?
                                • JCdes
                                  • Feb 2013
                                  • 91
                                  Yes con4 unplugged
                                  • Diah
                                    • Feb 2013
                                    • 6367
                                    you keep swimming at wrong direction... as you dont have the equipment to measure led in circuit currents.... put your DM 200.V DC red probe on any LED+ and test black probe on all LED- one by one when you turn on the set post your results each led -V No. --- this is -V currents boost circuit ( always i corrected this thought over this forum .. LED circuit / UNIT depending on current not Volts. ) so all yours parts replacement was just spending parts and time.
                                      Yes con4 unplugged
                                      So with the CON4 unplug, you get about 60V because the BL-ON will not be present, and with CON4 connected you get about 72V between LED+ as reported earlier, it should be close to 100V but it is not working correctly.
                                      So what is the test result of the D200 Boost converter diode?
                                      • JCdes
                                        • Feb 2013
                                        • 91
                                        72 is a one second peak... I'll do the d200 test tomorrow since I'm off work ti'll tuesday.
                                        • JCdes
                                          • Feb 2013
                                          • 91
                                          Also I ordered some d669's, all caps and the driver just in case I might need them. They will take about a week, parts are very cheap so I just ordered almost everything on the cold side except the "transformer" since I can't find part number for it.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • DKWS89
                                            Sony XBR 49x900E - Sound and backlight on but no picture
                                            by DKWS89
                                            Hey Guys,
                                            So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                            All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                            12-14-2023, 04:30 PM
