Sound and picture but no backlight
    Re: Sound and picture but no backlight
    Main Transformer T1 is fine and it is working otherwise you will not have the 5VSB (fed from always on 5V), Switched 5V (fed from always on 5V) and Switched 12V (fed from always on 12vV), and the 60V (fed from always on 60V) feeding the boost converter.
    • JCdes
      • Feb 2013
      • 91
      Pulled d200 and it's ok.
        No resistance reading on both directions, correct?
        And if you check the resistance of the two solder pads of D200 without D200 in place, what resistance do you get in both directions?
        • JCdes
          • Feb 2013
          • 91
          Originally posted by Diah
          you keep swimming at wrong direction... as you dont have the equipment to measure led in circuit currents.... put your DM 200.V DC red probe on any LED+ and test black probe on all LED- one by one when you turn on the set post your results each led -V No. --- this is -V currents boost circuit ( always i corrected this thought over this forum .. LED circuit / UNIT depending on current not Volts. ) so all yours parts replacement was just spending parts and time.
          Will do that tomorrow... I don't think replacing parts and spending 10 bucks in them is a waste as I consider it a learning experience plus new parts last longer after all. I'll let you know how the test came out.
          I would be lying if I told you that I think I did that and I only see a change in the multimeter reading if the corresponding led+ And led- pair for a specific strip are touched eg: First+ with first - which is the bottom strip pair, second + with second - which is the second to last and so on. So I will do the test cause I don't remember if I've done that already.
          Thanks for trying to help.
          • JCdes
            • Feb 2013
            • 91
            With red probe on middle pin of d200 I get resistance but with the probes on both ends (1 and 3) nothing. I'll do the test on the solder pads tomorrow after work.
            • Diah
              • Feb 2013
              • 6440
              i am sure you will find the issue soon.
              my points not about spending $ .. the problem we are facing knowing days.. spare parts become very bad manufactured. for me ONE Original parts of set tested working will never replace it even just for test only...
              good luck wish you.
                D200 is the Dual diode with Common Cathode (center pin), the two outer legs are anode and they are tied together to put the two diodes in parallel that is why you can see the trace connecting the two outer pins together.
                • JCdes
                  • Feb 2013
                  • 91
                  Ok, I will not be able to do tests today. Family matters that I must attend... So I'll ask you guys so that if I get home early I'll know what I'm looking for.
                  Diah: When I test the led+ With all the led-'s... What should I see? Should it give me a reading with all the -'s or only with the - that belongs to thats specific strip?
                  Budm: Should I see a specific resistance or none at all?
                  Once again thanks for the time you're spending with my problem and will to learn something new.
                    I expect the resistance reading to be in K Ohms range on the solder pads of D200..
                    • Diah
                      • Feb 2013
                      • 6440
                      yours POST #21
                      each strips contain same amount & Type of LED units, testing direct on + & - LED socket will show us if there are differences at pulling currents between the strips. in other words ( we are testing the build in ziner diode at LED unit ) which by time the value changed (decrease). this change LED tester would pass it as success test. but the power boards LED circuit will not pass it ( failed ) because its designed on certain currents depending on Panel size and the amount / type of LED units.
                      reading the high/ low value after powering up will tell us if our suspect correct or not.
                      • JCdes
                        • Feb 2013
                        • 91
                        Sorry for the long delay guys... I suffered a total rupture of my achilles tendon and have been recovering slowly... As soon as I can stand I'll do the tests...
                        • JCdes
                          • Feb 2013
                          • 91
                          My wife gave me this gift... Do you guys think it could work?
                          • JCdes
                            • Feb 2013
                            • 91
                            Recovery from this surgery is torture...
                            • JCdes
                              • Feb 2013
                              • 91
                              I can almost walk ok... I'll try to get back on this tv tomorrow. Gonna check the power levels you requested. Btw how about that board my wife gave me hoping it could work? Is it crap?
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • Ierwin
                                by Ierwin
                                05-13-2025, 03:31 PM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
                              • Mgiffune
                                by Mgiffune
                                06-09-2024, 10:28 AM
                              • DKWS89
                                Sony XBR 49x900E - Sound and backlight on but no picture
                                by DKWS89
                                Hey Guys,
                                So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                12-14-2023, 04:30 PM
