Vizio L32 HDTV10A - Wont turn on
  • lvvolvo
    • Mar 2016
    • 4
    Re: Vizio L32 HDTV10A - Wont turn on
    Back again. U26 is a linear 4.38 volt regulator. Mouser has this part in stock and I'll be ordering it since I have the same identical problem. Mine is not shorted but its not measuring correctly on my DMM. Hope this helps others.
      ASM809 is 3 Pin Microcontroller Power Supply Supervisor, it is not regulator:
      RESET THRESHOLD
      Suffix Voltage
      L 4.63
      M 4.38
      J 4.00
      T 3.08
      S 2.93
      R 2.63
      Features:
      • Monitor 5V, 3.3V and 3V supplies
      • 140ms min. reset pulse width
      • Active-low reset valid with 1.1V supply (ASM809)
      • Small 3-pin SOT-23 package
      • No external components
      • Specified over full temperature range - -40°C to 105°C
      You should show the picture of U26.
      • ivtec
        • Dec 2008
        • 1967
        RESET THRESHOLD
        Suffix Voltage
        L 4.63
        M 4.38
        J 4.00
        T 3.08
        S 2.93
        R 2.63
        Features:
        budm don't tire yourself trying to help these guys ,they think they know it all.they been ignoring you that's not nice.
        • lvvolvo
          • Mar 2016
          • 4
          As a follow up for the Vizio L32 flat screen, wont power up. U26 is a 4.38 voltage regulator. Even though this set was made in 2005 I'm sure these sets are still in circulation so its good information for us Certified Electronics Technicians to know about it.
            ASM809 is NOT Voltage regulator. Please look at the spec sheet and description and how it is being used in the circuit.
            It is Microcontroller Power Supply Supervisor with RESET THRESHOLD OF 4.38V (for 'M').
            • SS454
              vizio e650i-a2 backlight flashes then turns off
              by SS454
              vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
              panel: au optronics T650HVN05.4
              72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
              link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
              Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
              https://www.shopjimmy.com/vizio-56-0...-power-supply/
              Vizio 55.75J01.001G (91.75J10.004G) Main Board...
              08-20-2020, 03:57 PM
            • mrtek
              Vizio M65-C1
              by mrtek
              Hi.
              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
              07-14-2025, 07:28 PM
            • howardc64
              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
              by howardc64
              Failure Symptom
              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
              Where is the short?
              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
              05-27-2025, 02:56 PM
            • howardc64
              Vizio SmartCast TV software bug that looks like hardware
              by howardc64
              Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
              It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
              11-16-2024, 05:17 PM
