Samsung LED TV UN55J6201FA
  • jkb242
    • Mar 2012
    • 175
    This set has a BL issue for which all BL strips are on order. I need to isolate the BL issue once new LEDs are installed without the screen being connected to the TCON board. I do not want to reassemble the screen assembly until I know the BL works after replacement. Can I confirm BL operation without the TCON being connected? My plan is to monitor the BL for several minutes without the screen or TCON connected. Everything else about the set appears to be normal.
  • handsworth
    • Oct 2015
    • 175
    Re: Samsung LED TV UN55J6201FA
    Disconnect the power supply from the main board. Plug the power supply into the ac outlet. The power supply will turn on the leds. Samsung tvs have this unique feature, but I cant recall why it does it.
    • neilc6
      • Nov 2015
      • 1550
      Yes Samsungs have pullup resistors on the control signals so you can test the backlight with the main board disconnected.
      For other models, TVs will typically turn on with the panel disconnected. I always check the backlights before reassembly and again with the diffuser sheets replaced to check for any trapped dirt or dust or unevenness.
      • jkb242
        • Mar 2012
        • 175
        Thanks for the advice. I wanted to keep the initial thread brief without going into certain steps I took when investigating the no BL issue. Simply to share what I did next in troubleshooting the strips I’ll add here for an benefit to the forum, hopefully.
        Prior to opening the set I used a bright light to check for any display info and determined it was working but that’s about it whether partial screen or not that wasn’t my main concern at that point. Once I found the strips had several burned out LEDS, I decided to repair the strips since I am equipped to do and have done lots of SMD repairs. So I replaced about 15 of the 70 LEDs on 5 strips. When completed, I started the set without the TCON or screen attached and got a couple of flashes then no BL again. Furthering test showed many of the LEDs I replaced were defective again. Inferior 3v replacement LEDs? Wasn’t positive of that either. Then decided I would order a full set of working strips for this model. I did not have an LED set checker originally, so I tested each half strip separately using 20vdc with current limiting set to 500ma. All strips look fine but in the set, no joy. I concluded the issue was due to some connections inside the strips. Have not received the replacement strips yet but wanted to be sure that operation without the TCON or screen attached should allow normal BL operation before reassembling. Voltage 285vdc at LED driver connector and all series jumpers on the power supply board were solid. Hope this is beneficial to others.
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • Daren87
          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
          by Daren87
          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
          08-13-2023, 03:25 PM
        • Chrissygizmo
          samsung galaxy ao2s very temperamental after screen replaced
          by Chrissygizmo
          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
          Ive eventually managed to get it on and working but it's very temperamental...
          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
          05-26-2024, 12:05 AM
        • JunkmanJimbo
          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
          by JunkmanJimbo
          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
          Please help. Thanks in advance!
          08-12-2025, 11:45 AM
        • Kiberge
          Samsung LH82QENELGC/EN Help needed - Static line on screen
          by Kiberge
          HI guys!
          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
          04-22-2024, 11:28 AM
