LG 32LN578V No Backlight
  • menlopete
    • Dec 2020
    • 7
    • Ireland
    I got this TV free from someone who had this problem - namely sound is OK, but no picture.
    With a torch I can see the LG logo on powerup and there is sound when I plug in a HDMI source, so it can't be too bad, I thought.
    The guy who gave it to me had bought a replacement power board, but that behaves exactly the same way.
    So I metered the connector from the power bd to the main bd.
    Main voltages are OK. However there are three lines whose function I don't understand:
    pwr on 3.5vdc 6.4vac (I measured with the multimeter set to DC and AC)
    drv_on 3vdc 5.7vac
    pdim 1.1vdc 2.1vac
    I get no voltage out to the backlights.
    What next? Should I get voltage at the backlight connector even if disconnected? (I don't)
    Should I start looking for a new main board?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: LG 32LN578V No Backlight
    Check the backlight voltages again and see if there is a voltage that rises and drop towards zero just as fast. The min/max function is extremely useful if you have it on your multimeter. The voltages will be DC not AC at the backlight connection.
    DRV-On enables the backlight IC so it is looking like either faulty leds or IC801.
    Since the power supply has already been replaced then I would be looking at a failed led(s).
    • menlopete
      • Dec 2020
      • 7
      • Ireland
      Thanks for your reply.
      I don't have that function on my meter.
      It would appear that something happens when I power on - I get a couple of flashes of a reading on the meter, but nothing stable enough to read,
      • neilc6
        • Nov 2015
        • 1550
        No backlights or a flash of the backlights is usually a symptom of bad backlights. A 32" is usually not too difficult to take apart with a low risk of cracking the panel.
        https://techhometravel.com/lg-ln-ser...ed-backlights/
        • menlopete
          • Dec 2020
          • 7
          • Ireland
          I see no flashing at all on screen. It would be nice to know for sure before ripping the screen apart - is it possible to connect an equivalent load to check that the circuit powers up?
          • Diah
            • Feb 2013
            • 6374
            take the advice neilc6 gave to you.... after you take the screen apart you still can switch the set on and remain on with out LCD... you will see the BL how they flash for very short ms of time... remember all sheets you take out to access the BL should remain at same order when you put them back.
            • petehall347
              • Jan 2015
              • 4426
              • United Kingdom
              i recommend getting a back-light tester especially if you are going to be repairing more .
              example i just opened a nice looking pc monitor that isnt working . tested the individual led strips with panel still in one piece . 2 strips shorted . needless to say its not worth spending any more time on .
              2 strips test ok so will save panel in case i need the strips later .
              • neilc6
                • Nov 2015
                • 1550
                If there is an open circuit in the string, the LEDs won't flash. That size of TV, the LEDS are likely wired in just one string.
                  So if you leave Black probe on the chassis, Red probe on the LED + pin, meter is set to 200VDC scale, then turn on the TV you do not see any Voltage at all? It should have at least the DCV feeding the LED driver boost converter.
                  Also take the reading with and without LED connector in place.
                  • menlopete
                    • Dec 2020
                    • 7
                    • Ireland
                    Ah now that is very different - I was measuring between the LED + and - previously and getting nothing. Measured from chassis to LED + gives 125V regardless of LEDs being connected or not.
                    • neilc6
                      • Nov 2015
                      • 1550
                      For future troubleshooting, the main board sends two logic signals: PS-ON and BL-ON (sometimes labelled DRV-ON on LGs) to the power supply. If the BL-ON signal is sent and you have no backlight, the main board is likely good.
                      I have encountered some 4K LG models that turned on with no backlight and no DRV-ON signal. I usually search ebay for repair services for the main board to confirm if that model has a common main board failure (typically BGA issues).
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        The schematic shows the led voltage as ROW @ 80.4V, 400mA and POLA @ 70.3V, 400mA.
                        At 125V it looks as though you either have a faulty led(s) or a bad connection between the led strips within the panel.
                        • neilc6
                          • Nov 2015
                          • 1550
                          Without a LED tester and suspected open LED, you will need to scratch to expose the copper on one side of each LED and put your mulimeter in diode test mode to check every LED.
                          • petehall347
                            • Jan 2015
                            • 4426
                            • United Kingdom
                            i used to do that before i got the tester . the tester has actually fixed 2 tv.s somehow with no further work than testing and still working months later .
                            • menlopete
                              • Dec 2020
                              • 7
                              • Ireland
                              OK I worked up the courage to disassemble the screen, having never done it before.
                              And I discovered it's actually not too daunting a procedure.
                              So I have one bad LED strip, which I have now ordered.
                              Thanks for all your help guys - Peter
                              • neilc6
                                • Nov 2015
                                • 1550
                                A 32" panel is relatively stiff and small so low odds of damage though you need to be careful with the flex connections. Wouldn't recommend 55" or over without some practice with broken screen TVs and suction cups.
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  Do not make the fatal mistake of losing the order or direction the various panel sheets came off. You need to be put them back in the exact order they came off. Do not reverse any of the sheets.
                                  • triplefour
                                    by triplefour
                                    09-13-2023, 10:43 PM
                                  • robgerr
                                    Asus N580VN no backlight lcd. Main X580VN rev 3.0
                                    by robgerr
                                    Good morning forum. , This notebook has problems with the backlight being absent. If I shine a flashlight on the screen, i can see the image. I tried to change several LCDs but the same problem. When I disassembled it, I noticed the LVDS connector was a little burned in the backlight pins. I also found oxide in the LVDS connector on the motherboard. I replaced the LVDS cable, same defect. I replaced the LVDS connector on the motherboard, same problem. I took some measurements on the pins (I used the boardview of the X580VD).
                                    pin 36,37,38,39 19,40v
                                    pin 35 no connected
                                    pin...
                                    07-23-2024, 05:04 AM
                                  • DanPoka
                                    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                    by DanPoka
                                    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                    02-15-2025, 05:05 AM
                                  • cheeky2
                                    by cheeky2
                                    05-25-2024, 03:27 AM
                                  • Comp_Pro
                                    No Backlight Macbook A1990 820-01041
                                    by Comp_Pro
                                    Hello all,
                                    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                    Tests performed:
                                    There is no backlight even with a good screen.
                                    Backlight IC is receiving the correct support voltages.
                                    Fuse F8400 ok
                                    Current sense resistor R8400 ok
                                    Backlight IC is receiving 3.3V on enable pin.
                                    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                    Backlight IC receiving 5V from PP5V_G3S
                                    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                    05-06-2024, 10:23 PM
