Hi All, I have a LG 50PG70 Plasma TV that is in great shape with low hours. The only issue is it has 3 vertical single pixel lines on the screen, could this be a board issue or the screen ? Thanks in advance
LG 50PG70 Plasa with Single vertical pixel lines
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by Ancient1Hi
Asking for a friend.
I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
but here its the opposite !
TV has new T-con = same issue
A missing panel voltage would have global effect
So , what should one do ? how can I find where the fault is ?
Thanks !... -
by srsI'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables... -
by JRyanI found another TV by the road and took it home to try and fix it. This one has vertical lines as seen in the pic. I've disconnected both of the ribbons going from the tcon to panel one at a time and still see lines. Is the tcon board bad?...
by dustman1747I have acquired a Sony XBR-65X900H to try and fix. It probably was a complete no power situation. The main board was replaced and the TV started turning on. I now have start sounds and backlights, but no image. I've replaced the t-con with no improvement. Cables all appear to be ok and seated properly. The TV took a firmware update and hard reset but neither helped.
Using the tape trick I can get both side to display combinations of colored vertical lines. There is no change in the stripes and the pattern always appears the same. If I add additional tape strips I can get the screen... - Loading...
