samsung washer control board - DC92-01021H
  • ajshoe
    ajshoe
    • Dec 2012
    • 477
    • usa
    Have a Samsung washer - top load that only starts when it wants to. Normally pushing the start button after selecting the cycle - it won't start, just beeps. constantly adjusting cycle and hitting start may get it to work. I took out the control board (wax or gum coated) - don't see anything obviously wrong. Put in another used control board - washer works perfectly (start button works).
    Is there a way to remove this wax / gum off the board ( DC92-01021H) ? I'll post pics tomorrow morning.
    Most likely bad caps ? I read on another post - bad voltage regulator. thanks
  • CapLeaker
    Leaking Member
    • 8036
    Re: samsung washer control board
    heat that epoxy up with hot air then pick it off.
    • ajshoe
      ajshoe
      • Dec 2012
      • 477
      • usa
      Did back side. Not easy job.irs not epoxy - very soft. Gummy. It is clean thou. Work on top side tomorrow
      • petehall347
        • Jan 2015
        • 4425
        • United Kingdom
        cycle selector might need cleaning
        • ajshoe
          ajshoe
          • Dec 2012
          • 477
          • usa
          appears that all functions work -rotating the knob selects any cycle. the only fault is the start button doesn't start the cycle that was selected. The start button is acknowledge as I hear a beep when pressed. I can get the washer to start but is totally randomly. can't figure out sequence to get it to run consistently.
          • petehall347
            • Jan 2015
            • 4425
            • United Kingdom
            lid switch ok ?
            • ajshoe
              ajshoe
              • Dec 2012
              • 477
              • usa
              think you missed the earlier post - I put in a used control board from ebay and washer works perfectly
              • petehall347
                • Jan 2015
                • 4425
                • United Kingdom
                yes i missed that bit .
                • ajshoe
                  ajshoe
                  • Dec 2012
                  • 477
                  • usa
                  pics - found bad cap 10Uf 500V. replaced it - washer seems to work now. ran 3 loads with no issues.
                    Good job! where is the cap located? This will help lots of people. The conformal coating is always a pain to remove, yous is more likely to be silicone based conformal coating. Washer model number?
                    • ajshoe
                      ajshoe
                      • Dec 2012
                      • 477
                      • usa
                      Re: samsung washer control board - DC92-01021H
                      in the pic - it is the cap with the black x on top of it - top of the board (actually easy to remove and install new one). thought I put model # in topic - my mistake. Samsung washer model #WA50F9A8DSW/A2. Is there an easy way to remove that silicon coating ? I spent a lot of time peeling it off.
                      • CapLeaker
                        Leaking Member
                        • 8036
                        aah! Top left, first pic! Nice job!
                        • m1ch43lzm
                          by m1ch43lzm
                          05-12-2025, 08:37 PM
                        • ohren
                          by ohren
                          09-08-2023, 05:24 PM
                        • Yanleb
                          LG 60PK550 Logic Control Board EBR63450301
                          by Yanleb
                          Hi all, I just want to share the repair of my 60PK550-UA TV set.
                          The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                          But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                          All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                          C57: 3.30V
                          C61:...
                          07-20-2023, 12:38 AM
                        • C152Heavy
                          by C152Heavy
                          Summary for TL-DR readers:
                          • VCC pin (18) of PFC...
                          01-11-2023, 02:53 PM
