LG 50PJ550 Plasma tries to turn on then turns off
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hey guys,
    I have a LG 50PJ550 plasma that will not power on.
    When plugged in, the relays click and the screen lights briefly before the relays click again and it shuts right down. It then tries starting up again before giving up and just sits there with the red LED on. Pressing the power button again repeats the process.
    During the moment where the screen is on, there is a slight fuzz that starts to go away as most plasma's do when they turn on. So i do not think it is a panel issue as I get a normal looking image for a split second.
    I have tested the Vs and Va voltages to be around 60V and 150V when it is trying to turn on. These are not accurate measurements just rough values to see if there was voltage present. If something seems fishy about these values I can retest them properly.
    I have read that it is common for the large 2.2 ohm resistors on the Y-sus board to go bad but I tested them and they are fine.
    I have also read on this thread https://www.badcaps.net/forum/showth...hlight=50pj550 post number 7, that the power supply board can be powered up with no connectors connected to it. I unplugged all of the connectors from the power supply except for the AC input and the power supply clicks once when it is turning on then immediately clicks off again. While it is on I have 5V on the connector going to the Y-sus board. I also have around 60V and 150V on Vs and Va for the same connector. Since the board immediately powers itself off again, this suggests a fault with the power supply? Not sure what to check as it is still generating voltages.
    The story on this TV is that it was working fine before they turned it off for the night and then would not turn on the next day.
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Re: LG 50PJ550 Plasma tries to turn on then turns off
    Well, I found that there are power supply kits made for this TV so I looked at what parts are included and sure enough, that is my problem.
    The top-right ceramic power resistor on the power supply board is open circuit.
    The repair kit also comes with a new diode located beside the power regulator and the power regulator itself.
    I tested the diode in-circuit and it tested shorted. I removed the diode and it read 0.21V in diode mode. The datasheet says it is a Schottky Barrier Rectifier with very low forward voltage. So it seems the diode is fine.
    The large orange-blue-silver-gold-black resistor measures 0.5 ohms. I would guess this means 0.36 ohms so I guess it is alright.
    I am not sure how to test the voltage regulator IC. It is a 3BR1565JF. However, in other threads I have seen that it is recommended to replace the regulator anyways.
    On one of my other scrap plasma power supplies I found a 3BR2565JF. The difference between the two is the FET on-resistance is 1.5 ohms for the original and 2.5 ohms for the extra one I have. Will this difference be enough to cause problems? I do not test any shorts between the pins so I might just try it for now to see if the blown resistor is the only problem until I can get a new one from China.
    I will try to find a power resistor locally tomorrow.
    canadaboy25
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      More than likely the open resistor is the only problem, very common on that set.
      • canadaboy25
        What is normal?
        • May 2013
        • 509
        Yep, replaced the resistor and the TV is up and running. Was just worried there might be more wrong from reading all the other threads about this TV.
        canadaboy25
        • waakye
          ASUS ROG G750JM turns with no image and turn it's off within 7 seconds
          by waakye
          I was giving this ASUS ROG G750JM that exhibit the following behavior:
          When you press the power button, the computer turns with no image and turn it's off within 7 seconds. The battery charges when I connect the AC power. I tried flashing the bios with the uSB method and pressing Ctrl + Home and I can see the bios upgrade on external monitor.
          My issue is the laptop doesn't stay on for a long time and turn itself off.
          Any lead on how to resolve this will be appreciated.
          I cannot boot in windows and no liquid damage.
          Thanks in advance.
          09-13-2024, 08:10 PM
        • gabrielA7
          IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
          by gabrielA7
          Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
          I saw that the room LED lights up only when the screen is connected, so quiet.
          We have all the power supplies, even processor, 1.8V
          One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
          I suspect that there may be some leak in the processor.
          Anyway, when I press the power, it...
          10-29-2024, 06:48 AM
        • pajdek
          Lenovo Y700-17ISK turn on and off
          by pajdek
          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
          09-20-2023, 02:49 AM
        • JohnML1975
          Falcon FF32S53 turns off by itself then will not turn back on unless you wait
          by JohnML1975
          Dear Forum members
          I searched for a forum on this model TV and could not find so thought I would start a thread on this model and make
          I will upload some photos and share my trouble shooting steps so far
          07-20-2025, 12:28 AM
        • SluggerB
          Panasonic TH-50PX80 killed by lightning strike, help me save her!
          by SluggerB
          Yes it's a 17 year old Panasonic plasma!
          I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
          06-04-2025, 07:02 PM
