Vizio 65 LCD grey vertical bars
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi
    i have a Vizio 65 LCD that has great picture but has 4 vertical grey bars on the right half of the screen...
    they do not change..i tried swapping the ribbon cables..no change
    if i tap on the tcon board or tap on the bonded panel tabs the bars stay the same
    this makes me think it could be tcon issue or bad panel
    any input?
  • shelby5041
    • Feb 2009
    • 1505
    Re: Vizio 65 LCD grey vertical bars
    I replaced tcon and the vertical grey bars did not change...i have to assume lcd panel is trash
    • shelby5041
      • Feb 2009
      • 1505
      See photo
      I tried tapping on bonded tabs in those areas and the bars do not change at all
      • shelby5041
        • Feb 2009
        • 1505
        Does anyone know if this could possibly be a main board video processing issue or should i assume its a lcd panel problem?
        • Diah
          • Feb 2013
          • 6613
          panel had damage, actually the damage could be visible if you remove the screen bezel
          • shelby5041
            • Feb 2009
            • 1505
            Yes i removed bezel earlier..and..I found issue...4 of the ribbon cables to panel were torn....poor design...where its bonded it got cut on the sharp edge of the lcd panel...and tabs are on bottom of panel not top...which doesnt help...if it was on top it would happen since the gravity pushes panel away from ribbon cable...
            Tv will be tossed in trash
            You can thank the cheap poor design of lcd tvs for helping landfills getting bigger
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4541
              • Italy - Milan
              You can try a.fix, follow on this page the advice i gave to TV HELP, hoping at least you understand me...it a very simple concept..
              • shelby5041
                • Feb 2009
                • 1505
                Fix?..how do you possibly fix torn lcd panel ribbon cables?...please do explain.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4541
                  • Italy - Milan
                  Sorry, are them detached? Or cut? I don't know exactly how them appears.
                  • howardc64
                    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                    by howardc64
                    Failure Symptom
                    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                    Where is the short?
                    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                    05-27-2025, 02:56 PM
                  • otaku_nut
                    Vizio E701i-A3 fixed but now has red vertical line
                    by otaku_nut
                    Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                    08-19-2025, 06:11 PM
                  • x_orange90_x
                    Samsung UN46C8000XFXZA vertical bars/horizontal lines
                    by x_orange90_x
                    I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                    The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                    09-04-2023, 12:09 PM
                  • brad2157
                    Vizio E70-E3 Two white vertical lines
                    by brad2157
                    I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                    Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                    Replacement main board - Boots up fine, but starting...
                    12-13-2021, 05:11 PM
                  • ninja_zx11
                    Sharp LC-70LE650U vertical black and red bars
                    by ninja_zx11
                    70" LED TV is Sharp LC-70LE650U.
                    Initial problem was horizontal lines and slow motion lurrs on the bottom left of the screen. So I removed both the left and right ribbon cables from the T-con board and tried to clean it with alcohol and when I put it back, this issue appeared. I tried carefully reinserting the ribbon bon cables but same thing. I checked the traces of the ribbon cables with magnifying glass and everything looks good. I cleaned the small jumper ribbon cable on the left side of the screen which cured the horizontal line and slow motion blurs...
                    07-07-2023, 11:27 PM
