55as802b Pink tint
  • thuss
    • Jul 2012
    • 321
    55as802b Pink tint
    Hi
    I was after some advice. My mates panasonic 55AS802b has a pink tint to it especially noticeable on a white background.
    We have ran the lcd pattern test and all the other colours are fine apart from the white which is pink.
    My question is, can this be altered via the service menu through the whitebalance section r-gain g- gain etc?
    Is it the lcd screen or the backlights going faulty?
    from the service manual it states The test pattern is created by the circuit in LCD Panel.
    In LCD Panel test mode, this test pattern is displayed unaffected by signal processing for RF or input signal.
    If the normal picture is displayed, LCD Panel must be okay and the cause of failure must be in A board.
    (I assume its the lcd from the back of the tv through the vents the backlights do look pinkish)
    Any advice would be appreciated (My phone will not allow me to upload any photos at the moment)
  • Diah
    • Feb 2013
    • 6370
    Re: 55as802b Pink tint
    blue tint yes we saw caused by LED BL. but PINK ..LOL still not. it may the Red Gain little high .. calibration white balance are the answer if it was really PINK
    • thuss
      • Jul 2012
      • 321
      Hope these photos help - but when i do the routine picture test - picture is fine
        • 12187
        • U.S.
        Not pink, that's purple, usually caused by overdriven backlights, if that's what it is, the cure is new backlights and turning them down as low as can be tolerated.
        • Diah
          • Feb 2013
          • 6370
          not pink, that's purple, usually caused by overdriven backlights, if that's what it is, the cure is new backlights and turning them down as low as can be tolerated.
          +1
          • Diah
            • Feb 2013
            • 6370
            could you show us please with photos ?
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              As nomoresony says in post #4 the problem is that the led's have turned towards blue emission. If you search the forum for "blue leds" you can see examples.
              Replacing the leds and turning down the backlight is the solution
              • thuss
                • Jul 2012
                • 321
                Thanks for the info
                • thuss
                  • Jul 2012
                  • 321
                  9
                  Thanks for the info
                  Couldn't upload photos in one go the screen test starts with what should be white (pink) see above then rotates through the rest and ends up back with white(pink)
                  • thuss
                    • Jul 2012
                    • 321
                    Thanks for the help -one thing i noticed is that it doesn't effect it whilst its doing the picture/sound test .
                    • Diah
                      • Feb 2013
                      • 6370
                      those photos cant approve to you the issue we talked about LED back light
                      take out the back cover.. then you will be able to see thru many wholes the back light if its colored or pure cool white as it should be
                      • thuss
                        • Jul 2012
                        • 321
                        Thanks for all the help it was the backlights
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          To help stop them from failing again, turn down the "Backlight" as low as possible for viewing.
                          • thuss
                            • Jul 2012
                            • 321
                            Yes thanks set at 80
                            • gkolio
                              Sony Bravia 55w905a - 4 Red LEDs Blinking then Pink Tint
                              by gkolio
                              Hi have problem with 4 reds blink take lot help that forum and tell me change led strips and all going very good tv alive now but in down left have pink tint little and see only in white pages what wrong doing?
                              12-01-2023, 09:09 PM
                            • nono34
                              Hisense stuck in Colors cycle like test pattern.
                              by nono34
                              I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                              I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                              10-24-2024, 04:31 PM
                            • jimjoe123
                              LCD TV Green/Pink screen problem
                              by jimjoe123
                              I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                              Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                              Then each time...
                              02-23-2020, 01:29 AM
                              Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
                              This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
                              09-06-2024, 09:30 PM
                            • m3tal82
                              Sony Bravia XBR-65x900e Test pattern
                              by m3tal82
                              Hello all,
                              I got this beauty of a 65" Android Smart TV from a roommate whose boss through it out because it didn't work. I've fixed a few TVs before, but was being stupid on this one:
                              Original issue:
                              TV powered down after a minute or so, but picture was fine.
                              Tried replacing main board, which didn't work. I should have just replaced the AC Power board.
                              Months later, I replaced the power board, so I can see the screen. I lost / threw out my original main board, and there is now what I believe to be a defective main board in the TV. My symptoms...
                              04-07-2020, 12:41 PM
