LG Logo stuck 43UF680V
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Hi there does anyone know how to force past the boot logo, im suspecting corrupt firmware. tried leaving it for over an hour and still doesnt boot.
    contacted LG who kindly said they would send out an engineer, no thanks
    any suggestions appreciaed
  • nomoresonys
    • 12330
    • U.S.
    Re: LG Logo stuck 43UF680V
    First try freezing or heating EEPROM: 24C256, then see if the tv works for a little while.
    • Diah
      • Feb 2013
      • 6582
      did it response to remote control ?
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        No response to remote control other than turning on. Also to heat up i baked in oven 200°C for 15 minutes. Still the same.
        • nomoresonys
          • 12330
          • U.S.
          If you were trying to reflow led-free solder you need 217 C.
          • Mikeyboy2007
            • Mar 2013
            • 745
            • Scotland
            I have freezer spray so will try and freeze it. Will need to look for its location on the board first.
            • Nick's Tvs
              • Jan 2014
              • 621
              If you have it available, I would encourage you to use no clean flux when doing the reflow as well as mentioned by nomoresonys go a bit higher on the temperature. Is your oven convection? If so you don't want to keep it in there for 10 minutes, ideally you only reach your reflow temp for 30 seconds or else you run the risk of damaging the board.
              If you damage the board though there won't be any going back after you power it on. If you haven't done this before do you have another board you can practice on that's not so difficult and expensive to come by?
              We offer a repair service for this type of board. We have a very high success rate, but also use a $5,000 machine built for that specific process. Anytime a customer attempts repairs the success rate drops to 30%. I'm not trying to scare you into not fixing your own TV but I highly suggest you practice first and get a good idea of what temps and for how long. Then also consider that if you are successful the repair may only last for a few weeks to a few months if not less.
              • Diah
                • Feb 2013
                • 6582
                it mean to me it can receive RC command. so in this case send command IN_STOP will reset it and bring it back.
                • Mikeyboy2007
                  • Mar 2013
                  • 745
                  • Scotland
                  can you advise me where the location of this IC is as cannot find it ? under a heatshield maybe ?
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4540
                    • Italy - Milan
                    in many lg models this behaviour belongs to bad cpu soldering.
                    • Mikeyboy2007
                      • Mar 2013
                      • 745
                      • Scotland
                      i found the firmware chip, freezer sprayed it and no difference. i have noticed it responds to power on / off via remote control however it wont respond to in-stop or EZ-adjust signal. is there something else i could try ?
                      so if CPU soldering issue i could try as suggested in the oven with some flux at 220oc or so for 10 minutes. its a fan oven i have would this make a difference ?
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4540
                        • Italy - Milan
                        I don't suggest you to use an oven used also for food , this is not healty, buy a board of aluminum 4mm thick, and use it on a stove putting flux under the chip, when it warms you blow the flux paste under, when flux starts to make smoke wait a minute and then make some movement tests on the corner of the chip very gently until it moves a bit and returns by itself in the previous position, so you can stop the fires and let it cold down, open the the window and close the room door. The board must be big like the board. Use a big stove at the minimum.
                        • Mikeyboy2007
                          • Mar 2013
                          • 745
                          • Scotland
                          i also have a reqork station if this helps its a YH-853AAA from china. the cooler in question i would be using isnt used for food anymore
                          • nomoresonys
                            • 12330
                            • U.S.
                            Any further report on this one??
                            • Mikeyboy2007
                              • Mar 2013
                              • 745
                              • Scotland
                              didnt get any further, ended up stripping the set
                              • Teban1306
                                [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                by Teban1306
                                Hello everyone!
                                I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                System Information:
                                • Model: Lenovo ThinkPad T14 Gen 1
                                • Machine Type: 20S1S4E600 (Intel i7 variant)
                                • Current BIOS: N2XET42W (1.33) - Latest version
                                • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                What I'm trying to achieve:
                                Replace the default "LENOVO" boot logo with a custom image during POST.
                                🔧 What I've tried:
                                09-14-2025, 11:49 AM
                              • q2v5
                                Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                by q2v5
                                Lenovo T480s
                                Model 20L8-S3TE00
                                Board ET481-U10
                                Chip MX25L12873F
                                Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                08-15-2024, 10:40 PM
                              • martyjelen
                                iPad Pro 11 A2230 won't boot up - stuck at logo
                                by martyjelen
                                I have iPad which stuck at logo. Is there something I can do with it without data loss?
                                Thanks for your help
                                Martin
                                05-17-2023, 06:32 AM
                              • DynaxSC
                                MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
                                by DynaxSC
                                Hi Folks
                                I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
                                Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
                                09-29-2024, 04:27 PM
                              • x_orange90_x
                                Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                by x_orange90_x
                                I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                12-28-2023, 06:26 AM
