Vizio M43-c1 turn on and off
  • rustyshackleford
    • Oct 2020
    Good afternoon
    The television I have is a Vizio M43-c1. Currently when I press the "power" button on the remote the television turns on and displays the Vizio logo with no problem, but suddenly shuts off. After a couple of seconds or a minute it turns itself back on, and displays the Vizio logo again, then shuts off. Do you know what part I might need to fix the issue? I did replace the Vizio ADTVE1620AD5 Power Supply Board, and that fixed the issue for about a day. But now it continues to do the same thing again.
    Re: Vizio M43-c1 turn on and off
    Can we at least see the pictures of the whole backside of the TV showing all the boards so we can see what we are dealing with?
    What Voltage testing have you done when TV is working and not working?
    • Garret Matt.
      VIZIO (V555-H1) Television with odd cascading display fault
      by Garret Matt.
      I'm working on a Vizio Model V555-H1 that displays a cascading series of horizontal lines when first powering on. These lines appear to be in the shape of the Vizio Logo and descend until reaching the logo before resetting to the top and continuing their descent. I have reseated my TCON board and dusted connections but still have this fault displaying. I'm familiar with vertical lines but this one is a new one for me. My research into this problem hasn't yielded results as keyword searches point back to vertical line problems.
      Anyone have any recommendations? I...
      04-04-2025, 02:56 PM
    • Mulp
      VIZIO M65-C1 Does Not Turn On
      by Mulp
      Hi All,
      I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
      When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
      I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
      01-13-2024, 09:57 PM
    • Rolin
      Onkyo/Integra DBS-50.2 Blu-Ray Player - Won't turn on or shuts off immediately.
      by Rolin
      I have an Integra DBS-50.2 Blu-Ray Player that I haven't used in a while. Tried to turn on and it turned on for a brief moment with "hello" on the display then shuts off. Dead from that point on unless I unplug it and try again. Took it apart and checked a few well labeled voltages on the Power Supply board and found the 3.3V isn't measuring on the board (unless I'm misunderstanding what I'm measuring). I have a few pics of the board and schematics. There's a 4 PIN voltage regulator at location IC1301 with a part number 070XFC1 by Sharp that I believe should output 3.3V on PIN2,...
      09-07-2024, 12:11 AM
    • pajdek
      Lenovo Y700-17ISK turn on and off
      by pajdek
      Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
      09-20-2023, 02:49 AM
    • RdeveLabs
      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
      by RdeveLabs
      To all the members here...
      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
      05-05-2025, 04:59 AM
