I have a LG 60pv250, picture look good except for some what looks like noise that flashes on and off in certain areas across the screen. Grainy pic splotches. Looks like it would be an area across the screen horizontally. Also the tv stays on for probably 2-3 mins and then turns itself off. I can turn it back on but cycle continues. If I unplug the YSUS board the tv will stay on forever but no picture of course but have audio. Would this point to a bad YSUS board? I have already touched up the bad solder joints on the coils on this board as its a known issue. If it is a bad YSUS board do I have to replace the 2 buffer boards? I have seen opinions both ways. I have measured the voltages going to the YSUS and TSUS boards and both are identical coming from the power supply. Any help would be appreciated.
LG 60pv250 plasma tv issue
Re: LG 60pv250 plasma tv issue
Y-sustain, Z-sustain, and power supply commonly have cracked solder joints on these models.
I recommend you thoroughly reflow all 3 boards. If the issue doesn't get resolved, then you missed the cracked joints. there can be many dozens of cracked joints, sometimes hundreds. It will take a while to properly reflow all three boards but it will take care of the problem.
by celiabrownHello guys,
My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
Can someone has any symptom like this ?
Thanksโ05-09-2024, 10:56 PM -
by rouninHi everyone,
I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck โ hoping someone here can shed some light.
๐ Original Issue
The machine initially wouldn't negotiate 20V over USB-C โ stuck at 5V.
โ ๏ธ New Problem: One USB-C Port Only Works in One Orientation... -
by DoubleM257
by ugamazingI have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre... -
by shahnldGood day Experts
I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core... - Loading...
