Sony Bravia no picture but backlight on
  • capxrf
    • Jan 2010
    • 28
    Hello, I'm new to posting, but not at all new to reading here. Thank you all for all your past help you didn't know you gave!
    I just bought a really cheap Sony Bravia TV with no picture for myself to fix. I have a good deal of electronic repair experience, and have been doing a lot lately, so I figured this would be relatively simple, but no go, so here's the deal.
    It's a 32” (31.5” diagonally) Sony model KDL32s5100. The tv turns on fine. Green power light comes on solid and stays on. Backlights are bright. Unit is in great condition and hardly used it appears. Not tampered with.
    No picture though. No menu, nothing but backlit screen (screen is perfect). I can change the brightness with a combination of button pushes, so I can assume the menu is working, just I cant see the graphics.
    No bulged electrolytic caps. Touched up any iffy solder on power supply (no change). No cracks. All wire connections there. All insulators intact.
    Two strange things:
    1) I read 56 volts from 3 heat sinks on the power supply to ground (hurt to find out) (is this normal? I've never seen it)
    2) one pin off the power supply says 30v 2mA on the board, but only tests 17v. (I don't know why, and can't figure how everything can work but the screen if the power supply is bad)
    Any suggestions? Where should I be looking? I'm thinking main board, or power supply, but don't know what I'm looking for on the main, and the power is on.
    Any help is great, I really want to fix this one.
    Thank you !
  • capxrf
    • Jan 2010
    • 28
    Re: Sony Bravia no picture but backlight on
    Alright, I was more thourough today and tested the power supply again. All output wires are correct, (the two pins labeled pwr_panel tested at about 3.5v, I assume this is correct as everything else is and the two pins are identical) and the supply grounds are good. Still have 50 some volts over those three heatsinks, but i ust don't touch them, and they are obviously designed that way
    So now I'm stuck again. Anyone have any experience with this?
      • 31291
      download the schem's if you can find them - some are around.
      look for voltage regulators on the scaler/processing panel & check there outputs.
      • capxrf
        • Jan 2010
        • 28
        Thats where you lose me a little. What am i looking for in the way of voltage regulators? everything is tiny on the main board. Am i looking for a chip? I've been searching for schematics. I'm having a time locating any
        • capxrf
          • Jan 2010
          • 28
          Alright, I guess I need more help than i even thought. I can't find the service manual/schematics for the tv either. I found one for a model KDL-32L4000 and KDL-37L4000. The boards look the same visually, but the manual isn't for my model
          • infringer
            Badcaps Member
            • Sep 2009
            • 244
            • United Frickin States
            Look for chip id's with a magnifier look those ID's up ... You will find out what there functions are voltage regulators if you google that what does that bring up for you to me a complete newb anything that regulates voltage is a voltage regulator... So I see where you would be lost as well...
            But I remember chips that show LMXXX as being voltage regulators this may be what you are looking for as well...
            http://www.national.com/cat/index.cgi?i=i//75
            This may help you a little bit...
            Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
            • PlainBill
              • Feb 2009
              • 7034
              I've said this repeatedly to others, now it's your turn. Attach good quality pictures of the boards to your next post.
              PlainBill
                • 31291
                oh yea, there was a sony alert to repair centers about some large bravia's
                if you have a long board at the side with loads of invertor transformers on it, and it has a plastic cover over it - take the cover off.
                it traps the heat and causes faults!
                • infringer
                  Badcaps Member
                  • Sep 2009
                  • 244
                  Wow stj that is good information to know thanks a million man makes perfect since to me. Great tip.
                  • capxrf
                    • Jan 2010
                    • 28
                    Well, since the backlight is looking good and bright, would the inverter board even be an issue? All it does is backlighting right?
                    It's gonna take a while for photos to load up for me, but they're on their way
                    • capxrf
                      • Jan 2010
                      • 28
                      Here are the pictures
                      The first is of the back of the tv with all boards uncovered
                      second is the main board
                      third is a closer view of main board
                      fourth is the inverter board
                      fifth is the power supply
                      and last is the little board at the top of the tv between main board and LCD screen
                      • Wizard
                        • Mar 2008
                        • 2296
                        Blindly change to a video input with video and audio attached. If you get audio, that means TV is fine and whole LCD panel is probably good, that why I suggest check fuse on T-CON board, fuse is small and usually marked with a one letter and is very close to the LVDS connector. This can fail. That last picture is called T-CON (timing control). If fuse is still good, see if you can get one from sony or ebay or google may find one.
                        That one is a square cross section fuse with metal square end caps and it does have a number marked on white body. Fuse is just above the LVDS connector to the left. They sometimes fail for no reason. Changing fuse or solder a picofuse over the old fuse is sufficient.
                        Cheers, Wizard
                        • capxrf
                          • Jan 2010
                          • 28
                          Yes, I had already checked the fuse on the T-CON board (thank you for the new name). It tests positive for continuity. You said to "Blindly change to a video input with video and audio attached". The only connection like that I can think of is HDMI or the coaxial, am I correct? I'll have to find someone with an HDMI output device since I can't see anything to set up with my converter box... I'll get on that soon hopefully.
                          • Wizard
                            • Mar 2008
                            • 2296
                            Use the source that you can plug to the TV. composite, component with audio cables or composite even s-video with audio cables.
                            Trying to blindly tune to a channel is harder.
                            Cheers, Wizard
                            • capxrf
                              • Jan 2010
                              • 28
                              oh, well then yes, I can indeed get audio from Component #1 with the television. I can't seem to make the audio switch to the other sources though with the "input" button.
                              • Wizard
                                • Mar 2008
                                • 2296
                                This means mainboard is fine. Either replace the T-CON, but make sure you have voltage on that fuse. Failing that, LCD panel itself.
                                T-CON on used market is usually 50-120 dollars. Panel is around 800-1,500 in that size.
                                Cheers, Wizard
                                • capxrf
                                  • Jan 2010
                                  • 28
                                  Is there a way to determine which is the issue first? $50 would be worth it, but not if I found later that the screen was gone too (can't afford that for a free tv).
                                  • Wizard
                                    • Mar 2008
                                    • 2296
                                    Cannot do. Only way is get a T-CON and try. If not, you can stilll hold on it and get another one or sell the TV in pieces on ebay.
                                    Cheers, Wizard
                                    • capxrf
                                      • Jan 2010
                                      • 28
                                      Dang. Well then, I'll do some searching for another for a bit.
                                      I do have a "32 Toshiba Regza with a smashed screen. The T-CON boards on them look different, but just to check... this other tv couldn't help me any could it?
                                      • Wizard
                                        • Mar 2008
                                        • 2296
                                        Not compatible at all. Had to be *exact*. Sony is odd out.
                                        Spend that money, that Sony is way too good to waste. S5100 series is nice.
                                        Toshiba tend to use normal LCDs.
                                        Cheers, Wizard
                                        • DKWS89
                                          Sony XBR 49x900E - Sound and backlight on but no picture
                                          by DKWS89
                                          Hey Guys,
                                          So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                          All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                          12-14-2023, 04:30 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • ronni
                                          Sony KD-43XE8005 with sound, backlight, no picture
                                          by ronni
                                          I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
                                          When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
                                          Removing the LVDS cable results in...
                                          12-01-2022, 08:44 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
