Samsung UE40J5100 Blue threads in picture
  • JPElectronics
    John
    • Oct 2020
    • 7
    Samsung 40" LCD originally had no picture - I repaired that fault by replacing the T-Con (RUNTK 5538TP ZA).
    With the new T-Con the left hand half of the screen now shows what I can only describe as 'dynamic blue threads' which appear when there's any blue content in the picture. The right hand side is not affected. The attached photos show what's happening.
    Could my new T-Con be faulty? - it arrived from China wrapped in non-ESD (antistatic) bubble-wrap which is a concern.
    I've searched this forum but haven't found a similar fault mentioned - I hope someone here may be able to throw some light on this.
    Many thanks in advance, John.
    • 12128
    • U.S.
    Re: Samsung UE40J5100 Blue threads in picture
    I don't know for sure but I think you got a bad one.
    • diif
      • Feb 2014
      • 6978
      • England
      Have you checked the flat flex and connectors ? If you can't see any damage, try rotating the cable and see if the colour changes.
      • JPElectronics
        John
        • Oct 2020
        • 7
        Thanks for the suggestion Diif but unfortunately no difference to image after rotating the LVDS cable, I also gave the connectors a good spray with board cleaner to no avail.
        So it looks like nomoresonys wins this round.
        If the TV was mine I'd just go ahead and order another T-Con but I'll have to leave that decision to the owner.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          That looks a little like a solarized picture which you wouldn't expect with a replacement tcon. Measuring the VGx voltages on the Tcon may give a clue as to the problem.
          What is LVDS_SEL written on the tcon. Can you post sharp focused picture of the two tcons to compare
          • JPElectronics
            John
            • Oct 2020
            • 7
            Thanks for your help, DB.
            VGH = 32.4V
            VGL = 6.0V
            LVDS_Sel = 0V (So LVDS data format = JEIDA)
            • SoftwareHack
              • Oct 2020
              • 59
              I'm no expert, just an observation, but on the new board there's a pin on the right hand ribbon cable just to the right of center that doesn't appear to be connected compared to the old board.
              • JPElectronics
                John
                • Oct 2020
                • 7
                I was hoping an eagle-eyed sleuth like yourself may be able spot the problem but that pin buzzes out ok between the pcb track and the pin side of the connector.
                Even so - many thanks for your help, S/W Hack!
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  Is VGL +6V or -6V. I think VGL is normally a negative voltage.
                  • JPElectronics
                    John
                    • Oct 2020
                    • 7
                    Yes, VGL is -6V
                      09-07-2024, 05:50 AM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • JJAAMM
                      by JJAAMM
                      Problem
                      07-06-2023, 06:01 AM
                    • shelby5041
                      Samsung LCD TV no picture backlight on no 12v at tcon
                      by shelby5041
                      hi
                      i have a samsung lcd tv
                      it powers on with sound and backlight but no picture
                      all voltages from PS are good 12v 3.3v and 5v
                      whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                      i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                      no 12v at the tcon fuse
                      i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                      the odds of having 2...
                      10-08-2021, 08:21 AM
                    • Dodgethis
                      Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                      by Dodgethis
                      Hello all,
                      This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                      09-11-2024, 07:39 AM
