LG75SK8000PTA Blue screen no image shadows showing
  • wazzadj@hotmail.com
    Wazza
    • Nov 2017
    • 57
    Hi Folks ,
    I have a 75 inch Led Lg tv
    Model LG75SK8000PTA
    that has a strange problem
    i have no sound no picture ,
    i can turn it on and the backlights come on and I get a very dull Blue screen
    when I use the remote I can see a response like its trying to show a picture on screen but cant get a image just very dark shadows moving around the screen
    I have checked all the smps voltages are all ok and present
    I have replaced the Tcon board with a new one from LG
    I have checked and cleaned and reseated SVDC cables
    I have 12v at SMD fuse on both sides at the tcon board
    so I think I have a good Main and tcon board signal present
    my backlights seem bright enough from the back of panel when looking at them
    what could be the issue
    Can i follow the LG tcon test as per the training Manual on here
    your help is appreciated
    Thankyou
  • Diah
    • Feb 2013
    • 6613
    Re: LG75SK8000PTA Blue screen no image shadows showing
    nano cell, a good panel, i would start with reset the TV via IN_STOP command.
      Wazza
      • Nov 2017
      • 57
      Please can you explain further to NANO CELL reset the TV via IN-STOP command
      cheers
      • Diah
        • Feb 2013
        • 6613
        cheers
        we talked allot about IN_STOP. to know more you can google it or download it from this POST
          Wazza
          • Nov 2017
          • 57
          Thanks Diah for your assistance
          The problem i have is the TV has no picture at all
          just a faded BLUE screen NO Image is possible or Audio so i cant perform IN-Stop on it
          all my voltages are present and correct
          I have a new Tcon board
          when i unplug the right hand side SVDC cable on the tcon i get a white bar on the screen nice and bright picture, but the left hand side of the screen remains dull blue , i swaped to the right by unplugging the left and plugging the right back in on the Tcon and i still do not get a image it just remains blue
          I do get a very defined response from the remote control you can see shadows moving on the screen so i believe the main board is ok
          I have 13.2v at the fuse on the TCon board & 12v present on the 4pins on the 51 pin SVDC cable
          Is the lower Buffer Boards the issue maybe
          • Diah
            • Feb 2013
            • 6613
            show us please here photo on how it look the screen when you disconnect the ribbon cable between T-CON and panel ( you called them SVDC ) prefer with signal .
            BTW. try to access to lower Buffer Boards of the panel...you have on each side at this boards U ribbon cable at the middle . disconnected ..start with the fade blue side.. also prefer with signal..
            any further diagnostic always helpful if you upload photos over here showing the issue..
              Wazza
              • Nov 2017
              • 57
              Sorry Diah , my Bad i will upload some photos tomorrow
              the ribbon cables are the ones I am referring to coming from the TCon board at the bottom I will post up some pics to make it clearer to see what I am describing
              Thankyou
                Wazza
                • Nov 2017
                • 57
                I have now uploaded high res pics of the tv boards and the Tcon right hand cable disconnected as per your instruction with a source connected
                when I connect both tcon ribbon cables I get a dark blue faded to black screen
                no IMAGE No SOUND no channel or input display
                I have tested the tcon fuse ok 12v
                i have tested the lower FCC board where the tcon ribbon cables connect
                i have 13v plus 3.6v lines
                I don't believe it is the main board as I can see a response from the smart remote control like dark shadows moving when I press the remote
                thankyou
                  Wazza
                  • Nov 2017
                  • 57
                  Update i am still waiting on a LG service remote to be delivered so I can Perform a IN-STOP command
                  thankyou
                  • Diah
                    • Feb 2013
                    • 6613
                    thankyou
                    please check the following.
                    1- check on the side of Main boards sockets ( which it come from PSU ) if you have 20V.?
                    2-unplugg the wifi socket and check your TV screen.
                    Update i am still waiting on a LG service remote to be delivered so I can Perform a IN- command
                    if the points 1&2 above was done and no change. lets wait for yours LG service RC to send IN_STOP. if no change then it may we are facing BGA issue at the Main boards.
                      Wazza
                      • Nov 2017
                      • 57
                      Hi here is updated Photo of Original Fault condition showing No image
                      Backlight on
                        Wazza
                        • Nov 2017
                        • 57
                        DIAH just a quick Note ...
                        when I first received the tv it was showing this condition
                        so I thought it was a Tcon issue Reballing BGM chip
                        So I have a Heat bed I use for doing Ipads screens etc So I laid the Board down Chip face down & heated it for 4min at 150deg i then plugged it back in and I had the channel number and LG Logo come up on the screen for 1 Minuet
                        So that's why I thought it was the TCON board and ordered a new one
                        I have since replaced the TCON board with the new one from LG and the Photos of the Blueish screen is what I am presented with now
                        I am a little confused as to why the old Tcon Board responded after I heated it for a sec
                        But the new one wont respond at all ?
                        Anyway I will try the following instructions you stated and report back
                        Again thankyou for your assistance
                          Wazza
                          • Nov 2017
                          • 57
                          I cant find the Wifi Module to disconnect it WHERE IS IT LOCATED ?
                          When I measured all the voltages from the back of the PSU plug going to the MAIN i get all the correct voltages
                          according to the silkscreen table on the PSU board
                          pin 1 =20v
                          Pin 3=20v
                          pin 5= GND
                          Pin 7=13.2v
                          pin 9= GND
                          pin 11= GND
                          pin 13= PWR=ON
                          PIN 15=GND
                          PIN 19=20V
                          PIN 21= GND
                          PIN 23=DRV-ON
                          PIN 25=GND
                          PIN 27=V-SYNC
                          PIN 2= 20V
                          PIN 4= 20V
                          PIN 6=GND
                          PIN 8= 13.2V
                          PIN 10= GND
                          PIN 12=GND
                          PIN 14=PDIM-2
                          PIN 16=13.2V
                          PIN 18=13.2V
                          PIN 20= 20V
                          PIN 22= GND
                          PIN 24= PDIM 1
                          PIN 26=SCLK
                          PIN 28=SIN
                          • Diah
                            • Feb 2013
                            • 6613
                            now its clear.. as i thought first to run IN_STOP. the issue you have now that the replacement T-CON firmware on SPI ( empty or didnt match the Firmware on the main boards ) so you have functional TV with NO Picture.. but still you said there are no sound too... maybe because you didnt switch the source signal correct as you cant see screen
                            any way.. put the replacement T-CON always in use. and try downgrade or upgrade the firmware.. In-STOP will do it also to register T-CON & write from Temp the firmware at T-CON again. and do reset to main Firmware.
                            if this didn't work then you need to write it manually by replacing the spi flash of the old on the new one OR by dump the old and flash it on the new. ( ONLY IN CASE the 2 T-CON BOARDS 100% ARE IDENTICAL )
                              Wazza
                              • Nov 2017
                              • 57
                              oK diah Thankyou for your asssistance and expert help
                              i will try the N_STOP command
                                Wazza
                                • Nov 2017
                                • 57
                                OK Diah ,
                                I have now received the LG Service remote and performed a N-Stop command
                                but because I have no image I don't know if it is working
                                I press 0413 and the tv turns on out of standby i then press N-stop on the LG service remote and that is all
                                The tv turns off and that's it , I turned it back on and NO image
                                Can you assist further please
                                • Diah
                                  • Feb 2013
                                  • 6613
                                  OK Diah ,
                                  i recieved yours PM .. please keep writing over this threat only.
                                  IN_STOP how its work. when the TV ON (signs of the set are on : back light on. optical audio socket red led lit on ) front panel led indicators on most LG will be off when the set ON, and lit steady Red when set at standby or blinked if there are error so we don't give attention on it if its off.
                                  so. if you have the sign the set ON. send IN_STOP follow it with 0,4,1,3 the front panel led should turn on RED as standby... that's all... turn on the set and give time as the first install will be in place.
                                  if the issue after in-stop remain same as you showed us before.. and the T-CON was okay,, i would inspect the LVDS cable / sockets from both side either on main boards too.. LVDS & ribbon cable used by LG later 2018 sets and forward are cheap one where we found many burned line specially on LVDS by nano cells & OLED.
                                  thought repairing and following trouble shooting via writing hard task to me as i am non native english person.
                                    • 12323
                                    • U.S.
                                    If no luck maybe try re-heating your board the one you already heated that is, to 217 C, maybe bring it up to temp slowly and let it there for about half a minute then bring it back down slowly as to try not to thermal shock it.
                                      Wazza
                                      • Nov 2017
                                      • 57
                                      Hi Diah
                                      I received service remote and tried N-stop that did not work
                                      so I ordered and I put a brand new Mainboard in
                                      I have an instruction sheet that came with the mainboard from LG
                                      stating that I have to follow a 3 step process to make it work
                                      1. I have to make a USB disk and download from GPRS website portal a special firmware patch
                                      2.then I have to install it on the tv
                                      3.then I have to change the ID serial country number
                                      then I have to perform a N=stop command from the service remote.
                                      Problem is I can't access the GPRS portal as i am Not an authorised service agent so i am unable to download the file required
                                      I have checked the LVDS cables on the tcon board and the ffl boards
                                      they seem ok
                                      • Diah
                                        • Feb 2013
                                        • 6613
                                        Hi Diah
                                        you make it complicated and lost as we here the reader lost too.
                                        Now you have Empty T-CON with Empty Mainboards.. so if you cant have the patch firmware at any reason.. you need to put back yours Original Mainboards in place... then take out the SPI flash from the original T-CON, dump the firmware of it and write ( program ) it on the New T-CON SPI. so it should be and i did wrote it at the end of post #14
