Panasonic tc-p50s2
  • loonytu
    • Feb 2012
    • 10
    • canada
    Panasonic tc-p50s2
    I have 10 blinks and i was checking power and realize that the connecter p6 on power board pin number three has no 15 volts when turn on i only get .22 volts then off what could it be thanks for your help
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Panasonic tc-p50s2
    you have to be a bit more precise. connector p6, pin3 doesn't say too much unless you put the name of the function with it, like PSon etc.
    • loonytu
      • Feb 2012
      • 10
      • canada
      That p6 connector goes to aboard main board thats all i know
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        there should be a legend printed on either the front or back side of the main board.
        • u666sa
          HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
          by u666sa
          Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
          Platform: ipa32 la-m024p rev 1b
          Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
          I found a short on the other side:
          10-04-2025, 05:03 PM
        • BigPete
          Panasonic Heatpump Dryer Repair
          by BigPete
          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
          Unfortunately the whole machine has to come apart to fix it.
          I have...
          11-01-2025, 06:40 PM
        • Andre Gilbert
          by Andre Gilbert
          11-20-2024, 08:52 PM
        • supermattch
          HP 15dy-2021nr wont power on mystery volts
          by supermattch
          Hi everyone.
          I am diagnosing my personal laptop, because it wont power on and no leds light up.
          At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
          Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
          09-23-2025, 12:13 PM
        • AquaMan Ua
          Problem with PANASONIC CF53 laptop after changing BIOS settings
          by AquaMan Ua
          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
          05-17-2025, 09:40 AM
