Hisense LEDN40K Back lights
  • provider10
    • Mar 2016
    • 52
    • South Africa
    Hi All
    Got a problem with a Hisense LEDN40K. There is no back light . when I check the LED strips ( of which there are 8 with 5 LEDs on each one) I find that a lot of them are blown, there isnt one strip functioning. some have 2 leds working some none and in total there are26 LEDs blown out of 40. The weird thing is I have had this problem 4 times previous customers have refused the quote. But I would like to get to the bottom of this. does the PSU go faulty and blow all the LEDs.
    Any input would be gratefully received
    James
    Last edited by SMDFlea; 10-07-2020, 07:17 AM. Reason: Added LEDN40K to thread title
  • nomoresonys
    • 12322
    • U.S.
    Re: Hisense LEDN40K Back lights
    Is this the same tv that messed up 4 times?
    • provider10
      • Mar 2016
      • 52
      • South Africa
      NO i have had 4 different sets of this model with the same problem . The first three were returned unrepaired, but I would like to get to the bottom of this problem
      James
      • nomoresonys
        • 12322
        • U.S.
        I suspect an over-current situation, there he measures and does a fairly simple resistor mod to lower the current: https://www.youtube.com/watch?v=S2_WtM5DMx0
        • gabrielA7
          IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
          by gabrielA7
          Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
          I saw that the room LED lights up only when the screen is connected, so quiet.
          We have all the power supplies, even processor, 1.8V
          One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
          I suspect that there may be some leak in the processor.
          Anyway, when I press the power, it...
          10-29-2024, 06:48 AM
        • tennno`
          RCA LED46C45RQ,Sound but no Back lights
          by tennno`
          Sound no picture RCA LED46C45RQ,Power Supply Board RE46HQ1301.
          Has All voltages coming from main board.No voltage going to
          Back lights from power board.Have no Schematic.Back lights work when
          Led Back light Strip tester is used.Tester shows 110 volts from each
          side.Also if you use the side controls and use the vol +or- tv shuts
          down.
          Thanks for any help
          04-10-2022, 03:34 PM
          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
          I am comparing them to a brand new one that I installed
          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
          I going to let it run for several days before I remount back on the wall next to the...
          09-05-2024, 06:48 PM
        • boyebaran
          hisense 65k560 back light problem
          by boyebaran
          hi to all
          tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
          in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
          please advise me tnx
          05-20-2025, 07:11 AM
        • ratslap
          Hisense Roku 58R6E3 has back and audio, no image
          by ratslap
          The television screen is black but it is back lit. flashlight test doesn't yield any results as the screen is lit. the television just repeats a message about enabling or disabling the screen reader feature.
          first thing tested was unplugging the screen cables that lead to the tcon. when I unplug the right cable the screen shows half black on the left and white on the right. but when i unplug the the left tcon cable the entire screen remains black. From my understanding this indicates a screen panel problem. I have had previous success with covering some of the...
          01-26-2024, 04:24 PM
