Polaroid FLM-373B BSD Issues.
  • dacflyer
    • Jan 2019
    Hi all, it's been a while but i need help.
    I have this 2nd hand tv, I've had it a while now, and for the past year, I been tolerating a tuner issue.
    if the set is cold, the tuner will not work, i get a BSD and no signal on the screen, and the speakers make an annoying tic tic tic noise, when you turn the tv on, the ticking is strong, but then fades to a soft ticking after a while.
    All other functions work.. all button controls, HDMI , Video , Computer input etc.
    Strangely tho,,in the menu, if i goto the HDTV settings, there is none,, the menu just goes poof.. but i can get into the rest of the other menu fine.
    if i let the tv sit and warm up for a while, and cycle it on/off a few times, the tuner will finally start working.
    I'm wondering if this is a cold solder issue or a BADCAP...
    Any tips before i start digging into this thing...
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    Re: Polaroid FLM-373B BSD Issues.
    could very well be a bad cap. Heat up the tuner and or other parts of the main board with wifey's hair drier, turn the set on and see what happens. Just heat parts of interest enough not to burn yourself. 40 to 50C is more than enough.
    • snimmits
      Polaroid P43D300 (vestel 17MB97) issues (bluetooth & various sw bugs)
      by snimmits
      Good afternoon,
      I have a Polaroid P43D300.
      It shipped with WiFi and Bluetooth.
      Two weeks ago, I ran through the first time installation.
      This did a full reset and went through the first time setup.
      Once complete, I went to settings > sound.
      selected Audio Link, changed setting from disabled to enabled, pressed green button on remote and the tv does a search (discovery) for Bluetooth devices.
      search completes and doesn't find any devices.
      I have tried everything I can think of.
      Can someone provide...
      03-01-2024, 09:26 AM
    • DXseekerMO
      Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
      by DXseekerMO
      I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
      As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
      09-15-2021, 05:15 PM
    • SoulFreeze
      Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
      by SoulFreeze
      Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
      After repairing the above issue, I realized the following remaining problem,
      Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
      The computer recognizes headphones are connected and displays a popup in windows
      Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
      06-21-2025, 09:53 AM
    • Nagyesz
      Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
      by Nagyesz
      I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
      All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
      How can I extend its lifespan? Could reflow help?
      It has ryzen 5 5500h, rtx 2050, no soldered ram.
      Example of the artifacts:
      03-01-2025, 11:11 AM
    • pwnjuice
      Bitlocker issues
      by pwnjuice
      Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
      Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
      Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
      01-06-2025, 05:33 PM
