LG 47LS5700 ~ Image is faint, mostly white
  • kca
    • Feb 2016
    • 548
    Hello all ~
    I picked up this 47'' LG (47LS5700) Class 1080p 120Hz LED TV with SmartTV this morning and it is primarily in working order. The sound is good, and it powers on and off correctly. The image, however, is covered in a faint, white coloration that encompasses the entire screen. Some of the regular colors can be seen, but they are mostly "washed out" by the white.
    There also seems to be a distinction between the degree of white on the left half of the image as opposed to the right half.
    Thinking it's probably the T-con board, but I had a 65" Vizio a while back that also had a problem with the 1/2 left vs. 1/2 right side image and that was corrected by heating up the Main Board in the oven (strange, but it was the ony thing that worked).
    Has anyone seen anything similar before? I will post pictures in just a couple of minutes.
    ~ kca
  • kca
    • Feb 2016
    • 548
    Re: LG 47LS5700 ~ Image is faint, mostly white
    Here are several images to help with the diagnosis:
    {Sorry most of those pics uploaded upside-down. I don't know why it does that, but you get the idea of the "white, washed-out" look and problem.}
    I haven't opened up the back yet to look at any of the boards. Hoping to get to that this evening or early tomorrow. Also, I did not have it hooked up to a source when I took these pictures. Just brought it home and plugged it straight in. Hence, the "fuzzy" part of the image where a source image (DirecTV, AppleTV, or the like) would normally be.
    As you can clearly see from most of the photos, it acutally has 3 distinct shades of background white going on. One that takes up about 3/6 of the picture, another that is close to 1/6 and the final 2/6 is another background coloration yet. Eager to hear all of your thoughts. Thanks.
    • kca
      • Feb 2016
      • 548
      Wondering if anyone has seen this before and can confirm if the problem is the T-con board or not.
      I have taken it all apart, cleaned the connectors (especially the two from the Main Board and into the T-con) and reattched everything with no luck. Same result every time.
      I also baked the Main Board to see if that would have any effect. No dice.
      I will post a few more photos below as to what it does when the 2 ribbons leading from the bottom of the T-con out to the screen are alternately connected and disconnected:
      1) The full back of the set with all boards showingT
      2) Up close shot of the T-con
      3) Part # of the T-con (Only about $12 on TV Parts Today)
      4) When the left T-con ribbon is disconnected but the right remains in place
      5) When the right T-con ribbon is disconnected but the left remains in place
      6) When both T-con ribbons are disconnected
      About to order the T-con from TV Parts today, but if there is anything else I should check or anything on the T-con itself I should take a closer look at I would like to know before I place that order. Thanks to all for your subsequent help with this.
      ~ kca
      • petehall347
        • Jan 2015
        • 4448
        • United Kingdom
        is there a reset to factory setting ?
          • 12312
          • U.S.
          With tcons that reasonable, I'd throw one at it, see what happens.
          • kca
            • Feb 2016
            • 548
            Didn't try the reset to factory settings. I will do that. I did go ahead and ordered the T-con board after reading a few more posts on other sites. The board was $12.24 and the shipping was $14.95. Commerce in the age of Covid. At this point, I am pretty sure it's the T-con and very hopeful the new board will fix the issue when it arrives.
            • petehall347
              • Jan 2015
              • 4448
              • United Kingdom
              i generally set to factory to see it as it is and not how someone might have set it .
              • kca
                • Feb 2016
                • 548
                Forgot to get a picture of the entire set of boards from the back when I had everything unbuttoned, but I put all of the screws back in for now until the new board arrives.
                So, from the list up above, here are Images #2 through #6:
                • kca
                  • Feb 2016
                  • 548
                  Well ...... the new T-CON Board arrived today and it did nothing to change the behavior of this set.
                  Before it came in the mail, I had taken the back panel back off and tried the Factory Reset that was suggested earlier. Then, after I installed the new T-CON and realized nothing changed then I tried the Factory Reset while using the new T-CON as well. Nada.
                  So, I am kind of stumped. I have already baked the Main Board once to reflow the solder. That often works with these LG tv's, as most of you know. I guess I could bake it again but don't feel that is likely to be profitable.
                  If you take another look at the photos above in the prior post, they would be exactly the same if I were to post more with the new T-CON in play. The odd thing in the sequence is that when I remove the bottom right ribbon of the the T-CON I get the expected pure white screen on that side of the tv and the other side remains grainy. However, when I remove the bottom left ribbon of the T-CON I get that 1/2 image that appears to have a black background with the blue/pink/kind of green vertical stripes that run from the top to the bottom of the screen (4th picture in the set of images above).
                  Does that set of circumstances lead back to the Main Board as the likely culprit here?
                  I have kind of ruled out the T-CON as being the source of the problem because of the identical behaviors with the old T-CON in place as compared to when the new T-CON was installed.
                  Any help or advice would be greatly appreciated. Thanks in advance.
                  ~ kca
                    • 12312
                    • U.S.
                    Maybe test those little ceramic capacitors on your driver board, the one that is between the tcon and panel. You can test them for shorts or low ohms, multimeter set to 200 ohms test probe on each side of cap, see if any read short or read very low ohms, I would be suspicious of any testing lower than about 100 ohms, most will probably read higher, often only one is bad but it will make several read bad, one technique is to remove one bad one at a time and check it again off the board and recheck any on the board that were reading bad, when you get the bad one off the others will read ok, if that is the problem.
                    • kca
                      • Feb 2016
                      • 548
                      Hello ~
                      Thanks for that tip. I will test those but just want to make sure that I have interpreted your note correctly. When you say the driver board between the T-con and the panel do you mean the Y-Sustain board? (The one that immediately precedes the upper and lower buffer boards).
                      • William1967
                        • Nov 2017
                        • 217
                        • Netherlands
                        Look for (water) damage on the COF cables, the image also seems divided into 2. Had a similar problem due to waterdamage.
                          • 12312
                          • U.S.
                          Originally posted by kca
                          Hello ~
                          There is no Y-sustain board, it's an led tv, the board in question is the skinny panel driver board/s between the tcon and the panel itself, sometimes you need to remove some shit to get to them.
                          • x_orange90_x
                            TCL 50S535 bad tcon or panel issue?
                            by x_orange90_x
                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                            03-29-2025, 11:02 PM
                          • kca
                            by kca
                            Hello all ~
                            08-31-2025, 06:38 AM
                          • Daren87
                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                            by Daren87
                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                            08-13-2023, 03:25 PM
                          • Bloopeta
                            Samsung UE55JU6800K No Picture
                            by Bloopeta
                            Samsung UE55JU6800K with no image on screen.
                            I have had this TV many years without fault, however aprox 6 months ago I fitted a new set of backlights as some of the lens caps had fallen off.
                            Was working fine, until 3 days ago, when watching TV the screen just went blank (still illuminated)
                            I turned the TV off and left it around 12 hours, and when turned it on again it seemed to work perfectly again. After around 45 mins the screen went blank again.
                            Left it off overnight and turned it on, and the Smart TV logo came on as normal, then screen went blank.
                            05-03-2024, 10:42 AM
                          • jason123
                            ASUS PG27V Rolling Image - TCON?
                            by jason123
                            Hi there,
                            My son's gaming monitor started having rolling image (vertical roll - See Video) similar to vertical sync issue, or T-CON problems in TVs. Has anyone see this? is it fixable or a throw away?
                            I haven't even opened it up yet. Does it have a T-CON? Help is appreciated.
                            It does this even with the monitor not connected to a computer / graphics card....
                            11-01-2025, 05:41 PM
