Vizio, Powers off while on/sometimes doesn't power on
  • RainStorm
    • Mar 2019
    • 9
    Model: D65U-D2
    Got it for free, I started to play with the settings after opening my door to get some fresh air and it powered down twice on me after turning on the calibrated setting and turning on auto high brightness adjustment and black level adjustment settings.
    Sometimes it doesn't power on, when the tv shuts down while I'm using it it doesn't want to start but eventually will on the second time. I blew out the back of the TV with some air duster and that seemed to help some, but unsure as to what's wrong. The temperature difference outside and inside was a few degrees when I opened the door, but I live in a pretty humid area.
    I think the settings I changed increased the brightness and I turned on the high black detail and game low latency. I'm also on the 60Hz hdmi connection.
    Any advice? It's always done this pretty much on and off. As I'm playing with the backlight settings going from 95 to around 75 the tv seems to shut down. On Low backlight seems fine.
  • R_J
    • Jun 2012
    • 9624
    Re: Vizio, Powers off while on/sometimes doesn't power on
    If the tv stays ON with the backlights lowered, it is a good chance you have a bad led in the backlight string, it only takes one.
    • nomoresonys
      • 12331
      • U.S.
      May be one or more bad capacitors on the powerboard, just had similar symptoms with one of my old tvs, 5 bad caps that were obviously bad but sometimes they look good but can be bad, seems like the startup caps are the ones that like to crap out first, just a possibility.
      • nomoresonys
        • 12331
        • U.S.
        Guess I missed your last sentence, "On Low backlight seems fine" yes that's a pretty good indicator of bad/weak backlight/s.
        • csmith
          Vizio D50u-D1 Powers up no picture
          by csmith
          I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
          Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
          supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
          issue. Set will power up with remote but not power off....
          07-11-2025, 11:52 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • JaquesPratt
          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
          by JaquesPratt
          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
          07-16-2024, 01:04 AM
        • npolite
          Vizio E320-A1 Powers on But No Display
          by npolite
          Hi All,
          I have a Vizio E320-A1 which lost sound and picture. The power LED comes on and stays on but nothing else works. I am not able to power it off unless I unplug it.
          Here are the voltages when the power is on
          1 - 5.25
          2 - 5.25
          3 - 0
          4 - 4.8
          5 - 25
          6 - 25
          7 - 0
          8 - 0
          9 - 0
          10 - 12
          11 - 12
          12 - .9
          13 - .5
          Can someone let me know if the issue is with the mainboard?
          Thanks...
          04-19-2024, 11:33 AM
        • ossroy
          Vizio M60-C3 powers on, perfect logo, turns off
          by ossroy
          Vizio M60-C3 powers on, perfect logo, turns off. If you don't touch anything it will repeat this process by itself until it is unplugged. Not the "button board" since I disconnected the cables to the main board and the problem persisted. So I'm fairly positive something is going on with the main board, but want to know if there is a fix for this other than replacing the expensive mainboard, which may eventually have the same problem. Also, heat sink was hot as hell when this all started. Unplugged for a few days and same thing happens.
          My kids are getting antsy waiting...
          08-03-2022, 08:11 PM
