Sony KDL-60R510A - Bad tcon or panel
  • knoxrebel
    • Oct 2009
    • 168
    Was originally getting the Sony logo with this washy fading in and out. now it just powers on to this. https://youtu.be/qIkFKpy8JAM
    Sorry in advance about the rotate issue.
  • knoxrebel
    • Oct 2009
    • 168
    Re: Sony KDL-60R510A - Bad tcon or panel
    Here are also pictures of the boards.
    • knoxrebel
      • Oct 2009
      • 168
      Bump
      Any assistance would be welcome in testing tcon i have searched and cannot find testpoints or pinouts.
        • 12274
        • U.S.
        Try powering up tv with one ribbon cable unplugged from tcon to panel, see what you get on display then plug it back in and try it with the other side unplugged, good policy to make all connect and un-connects with tv unplugged from power so you don't get any unwanted surges.
        • knoxrebel
          • Oct 2009
          • 168
          Thanks for the reply. I ordered another T-Con board. And now I'm getting video (sort of) with the old board and new boardS.
          • knoxrebel
            • Oct 2009
            • 168
            SOLVED: TV was trashed. A ribbon cable that connected boards on the lcd panel itself had a burn mark in it as well at where that board attached to the lcd ribbon flex cable had trace damage that couldn't be repaired without specialty equipment.
              • 12274
              • U.S.
              Ok, yep your pictures look just like many others with that kind of damage.
              • iglitare
                by iglitare
                09-04-2025, 07:13 AM
              • kca
                by kca
                Hello all ~
                08-31-2025, 06:38 AM
              • rimwall
                Sony KD-65x8500b - bad Tcon or panel?
                by rimwall
                Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
                a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
                b) the Tcon board is malfunctioning,...
                10-24-2023, 07:58 PM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • netgearnetgear
                TCL 43S423 TCON OR PANEL FAULTY???
                by netgearnetgear
                Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                08-20-2025, 06:04 PM
