LED TV doesn't want to turn on
  • darkwarrior92
    • Sep 2020
    • 10
    • Denmark
    Hi everybody!
    I'm having a problem with my "Vivax" LED TV, the problem is there is a standby light, but TV doesn't want to turn on, the button have solid light (like it should when it's on a standby), but it's not reacting to remote or power button on a tv.
    Tv was working ok before this problem, one day it was turned off by a remote, and since then I can't turn it on again.
    I have opened TV to check if there are some swollen capacitors on main or power board, but they all look good. I have used a multimeter to check voltages between those two boards, you can check on a pic I've added for voltages, written in black is what is written on a board, and red values are the values I have measured.
    To me voltages from Power Board looks good, but i don't know what to say about Main Board, since I'm not an electrician, so the only thing I know to do with multimeter is to measure voltages.
    I'm suspecting that it's maybe a main board, or a little board that is used for power button and IR, but actually I don't have a clue what it could be.
    Thanks in advance for any suggestion
    And this is how boards looks:
  • Diah
    • Feb 2013
    • 6355
    Re: LED TV doesn't want to turn on
    yes it MB issue and it seem firmare issue or spi
    ist the system Android ? or Chinese one which it used also at LCD projector ?
    • darkwarrior92
      • Sep 2020
      • 10
      • Denmark
      It's not Android, it is a regular TV (non smart). I think main board is made in Turkey.
      • Diah
        • Feb 2013
        • 6355
        can you see any label S/N on the main boards?
        • neilc6
          • Nov 2015
          • 1550
          Tv not turning on could be a bad eeprom if you have standby voltage. Freeze it with an upside down can of duster before plugging in. 8 pin soic with white dot beside processor.
          • Diah
            • Feb 2013
            • 6355
            i think the spi beside it .. the one covered with white silicon this is Chinese way to cool it down LOL
            • darkwarrior92
              • Sep 2020
              • 10
              • Denmark
              @Diah
              Model: 12AT011_v1.0_A
              @neilc6
              Is there any other way to freeze it?
              • Diah
                • Feb 2013
                • 6355
                carefully remove the white silicon on the part near to the corner of the main ic let see what hidden the spi flash or not
                • darkwarrior92
                  • Sep 2020
                  • 10
                  • Denmark
                  This is what it looks like without white silicon:
                  • Diah
                    • Feb 2013
                    • 6355
                    so U11 the spi flash... try freezing it to see if the set complete boot and run.. can you read the label on U11
                    • darkwarrior92
                      • Sep 2020
                      • 10
                      • Denmark
                      I think it's 25Q32, but I will check tomorrow, it's late now. A problem is that I don't know where to buy a new blank chip, I could buy it from ebay or aliexpress, but it would take forever to receive it, so maybe I will just go for a working used main board which is about 30 EUR.
                      • neilc6
                        • Nov 2015
                        • 1550
                        You can stick the entire board in the freezer.
                        • darkwarrior92
                          • Sep 2020
                          • 10
                          • Denmark
                          Ok, I will try that, but I will put it in some bag first, because of a moisture from the freezer.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            A quick squirt of butane (lighter gas) is far better than putting it in the freezer.
                            • petehall347
                              • Jan 2015
                              • 4426
                              freezer might not work enough .been there done that . if you use gas do it outside if you can or as close as you can like near an open outside door .. gas heads for the floor and looks for ignition sources .
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                How much are you squirting out to be worried ? It will be gone before it hits the floor.
                                • petehall347
                                  • Jan 2015
                                  • 4426
                                  enough to freeze the bloody things ..good few seconds . must splash out again 1 day for the real freezing stuff .not had any for years . my brother set fire to our bedroom when we were kids .was filling a cig lighter and i said just burn off what went on the floor .. unbeknown to us the beds were stuffed with straw . beds were from the late 60.s . this was in the early 70.s . it happened very quickly hence my warning . lighter gas is very volatile .
                                  • darkwarrior92
                                    • Sep 2020
                                    • 10
                                    • Denmark
                                    I've tried putting a board into the freezer for couple of hours, but unfortunately the problem remains the same.
                                    Are you sure that it's not a IR/button board problem, by looking at first picture I've made (the one with measured voltages)? I'm now even closer of buying a working used board, because a can of duster is about 10 EUR, and I don't know if that's gonna work, while board is 30 EUR, but I don't want to spend money on a board if I'm not sure that main board is faulty.
                                    • darkwarrior92
                                      • Sep 2020
                                      • 10
                                      • Denmark
                                      Anyone?
                                      • petehall347
                                        • Jan 2015
                                        • 4426
                                        try lighter gas .
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • maxim2511
                                          LG 55EC930V OLED - swich on swich of no screen
                                          by maxim2511
                                          My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                          Then I get an idea to take it apart and clean boards from dust.
                                          In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                          Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                          05-14-2021, 02:21 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • canadaboy25
                                          Panasonic TC-P54VT25 No image. A or D board?
                                          by canadaboy25
                                          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                          01-17-2021, 01:06 AM
