Samsung QLED TV disassembly....impossible?
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Has anyone in here figured out a way to remove a screen from a Samsung QLED TV without it getting tore up? I've got one here that needs backlights...but the screen appears to be bonded to the chassis.
    Thank you everyone!
    They call me......."threadkiller"
  • tonebells
    • May 2016
    • 15
    Re: Samsung QLED TV disassembly....impossible?
    https://www.badcaps.net/forum/showthread.php?t=24661
    What model TV is it?
    T
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      Sorry about that....I shoulda known to post the model number.
      QN55Q6FNAFXZA
      • Biruslapio
        • Nov 2013
        • 552
        • Brasil
        https://www.badcaps.net/forum/showthread.php?t=83293
        This post gives a hint towards the construction of the TV, probably glued really strongly on the top and bottom
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          Well that will teach us techs to fix someone's Samsung QLED TV. The days of these types of repairs are growing short.
          Thanks a lot....Samsung
          • ariastar22
            • Oct 2019
            • united states
            I found how to remove the panel, anyone attempting I wish the best of luck.
            https://www.youtube.com/watch?v=3hLXL4NcH28
            • brucetv
              • May 2015
              • 281
              • united states
              Samsung quality has really gone down hill since the MU series and and the newer models are designed to fail prematurely and engineered to make it harder to repair even for seasoned technicians. The video is a panel repair facility with very expensive panel repair laser soldering machines that are not at our disposal but it does give you a example on how panels can be repaired when tab bonds are damaged. On the bezeless designed tv's the bottom of the panel fits down into a thin bezel and the other 3 sides use a wide strip of 3M two way adhesive to hold the panel down to the chassis. Even though it looks nice it's a recipe for disaster. Welcome to the world of todays Samsung engineering. MU series=bad panels...NU series=could be a array of poor quality problems. RU and TU series=usually bad backlights or poor quality power supplies and mains, as well as more shorts on the panel driver boards. QN series use surge happy power supplies, mains, cheap backlights and more panel driver shorts. Heaven help you if you have any backlight problem on the new NEO led Tv's after your warranty is up. And now they are admitting to the use of a Tv Blocker App secretly embedded onto your software where they can remotely brick your tv whenever they want. Do you really trust them to use it responsibly? A look at Samsung's reputation for being corrupt is a hint. Buyer beware and for all those that have newer Samsung's keep Auto Update off on software version updates. It's a shame because they have nice picture quality but designed to fail in 2 to 3 years now. Shameful. Charge more on QN series backlight repairs and I usually turn them down now. I'm too old for that mess.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Looks like only phones, SSDs and RAM from Samsung now!
                I got two defective Samsung NU6900 series TVs in-a-row!
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • Chrissygizmo
                  by Chrissygizmo
                  02-10-2025, 12:33 AM
                • Chrissygizmo
                  samsung galaxy ao2s very temperamental after screen replaced
                  by Chrissygizmo
                  Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                  Ive eventually managed to get it on and working but it's very temperamental...
                  The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                  05-26-2024, 12:05 AM
                • JunkmanJimbo
                  Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                  by JunkmanJimbo
                  Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                  No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                  Please help. Thanks in advance!
                  08-12-2025, 11:45 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • Kiberge
                  Samsung LH82QENELGC/EN Help needed - Static line on screen
                  by Kiberge
                  HI guys!
                  I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                  I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                  the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                  This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                  04-22-2024, 11:28 AM
