can i swap a 7N60B for a 10N60 transistor
  • finntricky
    • Jan 2014
    • 449
    • uk
    or can i go any lower than 7N60, reason i ask is, i have just removed the shorted 7N60 and only had a 10N60 to replace with, but i have no voltage on the cold side of the board and don't know if the 10N60 is what is the problem, also the heat sink that it is on gets very hot.
    this is the power board on a TECHNIKA 40 LED, MEGMEET MP118T
    Re: can i swap a 7N60B for a 10N60 transistor
    Please attach good clear pictures of YOUR board so we can see what we are dealing with.
    • magneh
      Behringer Eurolive B205D repair - help identifying transistor
      by magneh
      Hello
      Got this speaker from a friend , defective. Power led comes on and off , in a loop.
      Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
      After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
      I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
      Still, I need to replace this transistor....
      06-18-2025, 02:34 AM
    • elsomer
      help to identify transistor msi ms-15ck1
      by elsomer
      hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
      02-17-2025, 05:30 PM
    • rddube
      Help with blowing transistor NAD T752 receiver
      by rddube
      I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
      Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
      I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
      09-01-2022, 05:19 AM
    • amigo744
      xbox series x u82 5 pin transistor voltages ?
      by amigo744
      hello there,
      xbox series x hdmi u82 transistor 5 pin,
      can anybody tell me voltages of this transistor in standby and power on mode ???
      on which pin of this transistor are the voltages ?
      regards
      08-16-2023, 08:05 AM
      AO4601 AO4601L Transistor (Applications Laptops) Datasheet
      Complementary Enhancement Mode Field Effect Transistor
      The AO4601 and AO4601L use advanced trench technology MOSFETs to provide excellent RDS(ON) and low gate charge. The complementary MOSFETs may be used to form a level shifted high side switch, and for a host of other applications. Standard Product AO4601 is Pb-free (meets ROHS & Sony 259 specifications). AO4601L is a Green Product ordering option. AO4601 and AO4601L...
      11-05-2024, 08:21 AM
