TCON board compatibility question
    replied
    Re: TCON board compatibility question
    Did you check the Gamma Voltages?
    How about providing good clear straight shots of the whole T-CON board.
    What is the history of the TV?
  • Themi
    replied
    Originally posted by Diah
    different screen size are different T-CON firmware.. other things shape sockets etc identical.. search after your screen serial No , which i guess its V650dk1-ks2 rev. Ha
    or post here your faults of the T-CON as here many members could help by test and repair.
    I see, that makes a lot of sense, I wasn't aware firmware changed.
    This is the error I get, screen looks washed out, colours are very unsaturated, everything else appears to work fine.
    https://ibb.co/J7dy54M
    I have removed the TCON board and visually inspected it and see no obvious faults. I have checked each capacitor, 0ohm fuse, fuse, inductor and all seem to be ok (tests onboard with multimeter).
    I have tried replugging in all the flexi cables but there is no change.
    I have done some basic checks to see what voltage it is getting and around the DCIN for the TCON I vaguely remember getting:
    1.2v
    8.7v
    12v
    17v
    (I can reconfirm these if you like)
    Out of curiosity, if I were to be unable to repair this one and buy a new V500DK1-CKS1 which came from a different model of TV then desolder and transfer over the firmware chips from my current TCON board, would this work?
  • Diah
    replied
    Originally posted by Themi
    Thanks. If I buy a V500DK1-CKS1 from a 58 screen what will be different about it? The ribbon connectors or something else?
  • Themi
    replied
    you can use T-CON any from vestel TV brands with boards V500DK1-CKS1 but it should be for 65 screen as yours tv size
  • Diah
    replied
  • Themi
    started a topic TCON board compatibility question
    Hi all just a quick question.
    I have a TX65-AX802B Panasonic screen which has a faulty TCON board. The TCON board model number is V500DK1-CKS1. Can I use any other TCON with the same model number or are TCON boards matched specifically to the TV model number they are paired with?
  • Hakuu
    by Hakuu
    Hi There,
    More Details
    TV Model - LG OLED77G1PUA
    07-12-2023, 02:37 PM
  • advant
    by advant
    02-03-2020, 12:25 AM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • rustinjust
    Technika lcd 32 - 207, question about board compatibility
    by rustinjust
    My main board is a 17MB12-2 and reads underneath that the following number 160807 LF,
    Question is this board going to fit? ( see link) board is identical but from a different brand of tv but board number is same as in that it’s a 17mb12-2 board
    Link to part here https://www.ebay.co.uk/itm/222990805243
    This board is cheapest I can find. Also note:ordered one that was from a technica, an exact replacement, it arrived yesterday and when I fitted it it was a dead board, didn’t even show the standby light. When I piut the old board back in the tv worked but the issue...
    10-06-2023, 08:53 AM
