Technika lcd 32 - 207, question about board compatibility
  • rustinjust
    • Jun 2022
    • 49
    • England
    My main board is a 17MB12-2 and reads underneath that the following number 160807 LF,
    Question is this board going to fit? ( see link) board is identical but from a different brand of tv but board number is same as in that it’s a 17mb12-2 board
    Link to part here https://www.ebay.co.uk/itm/222990805243
    This board is cheapest I can find. Also note:ordered one that was from a technica, an exact replacement, it arrived yesterday and when I fitted it it was a dead board, didn’t even show the standby light. When I piut the old board back in the tv worked but the issue is it will stick on one tv channel after awhile and not change channel so I figured a replacement main board might fix the issue, so will the one in the link from an acoustic solutions tv work?
    They are generic boards/ vessels used in many tv brands
  • rustinjust
    • Jun 2022
    • 49
    • England
    Re: Technika lcd 32 - 207, question about board compatibility
    Any useful advice from an expert on this appreciated ��
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      i think also the number starting with 203 is important to match up.
      • rustinjust
        • Jun 2022
        • 49
        • England
        The number starting with 203, where will that number be found? Is it on a sticker on the board?
        • rustinjust
          • Jun 2022
          • 49
          • England
          Anyone??
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            on a white sticker usually (i can see it on the ebay link picture)
            • rustinjust
              • Jun 2022
              • 49
              • England
              So as well as the board numbers needing to match it also needs the barcode sticker to match or it won't be compatible??
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                This is what i had found mentioned online when i needed to order a replacement vestel main board
                Vestel Main Boards; Finding your Vestel Main Boards P/N is just the same as the VESTEL PSU. The blank board number will just be '17MB', then finding the vestel P/N is a case of looking for a white/ green/ red sticker label and locating the '20' or '23' number within it, which will be 8 digits long. This number must match in order to GUARANTEE compatability.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • edugimeno
                  Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                  by edugimeno
                  Hi!!
                  Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                  I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                  At a certain point, moving stuff around, I put all wires back in place and...
                  03-24-2024, 02:31 PM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
