My Insignia TV is showing a horizontal bar stretching across the middle of the screen from left to right. The bar is not completely black and is still showing some light. I found it weird because the bar covered 1/3 of the screen, just the middle. Does someone know what happened and how to fix it?
Insignia 24” ns-24e340a13 LED HDTV
Tags: None
Re: Insignia 24” ns-24e340a13 LED HDTV
What is the history of the TV?Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
The TV was used when I bought it and it would have a problem which when I would turn it on at the start of the day it would show a ring near the border of the TV. I would push the screen gently and it would fix itself. The same problem happened again so I pushed the screen but that part in the middle stayed. The whole screen used to have that in the picture but the middle part stayedAttached Filesif you find these attachements useful please consider making a small donation to the site
Did you open it up and re-seat the cables?Never stop learning
No I did not. I was pressing on the screen and then that happened. I opened the back of the TV to see what was wrong and I touched a few wires and that's all.Comment
You can try re-seating the LVDS cable.
Show us the pictures of the backside of the units so we can see all the boards.Never stop learning
How do I re-seat the lvds cablesAttached Filesif you find these attachements useful please consider making a small donation to the site
You picture does not show the whole back of the unit, I cannot see the LCD panel LVDS connector.Never stop learning
You just squeeze the left and right sides to release the lock.Never stop learning
The connector on the LCD panel, just remove and reinsert back in place (re-seating).
No power to the unit!Never stop learning
At this point you have panel problem.Never stop learning
The panel.Never stop learning
You panel has integrated T-CON. the horizon bad is due to Gate drive issue.Attached Filesif you find these attachements useful please consider making a small donation to the site
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... -
by burbutsalosHello everyone.
I have this TV set which has this issue. It shows a vertical bar im the middle of the screen.
The panel has 12 cofs and the problem seems to be on the territory of the first cof on the right side.
The tv fires up and you can see a good picture exept that vertical part where multicoloured pixels exist.
The strange thing there is that you can see behind that snow that it shows picture but as if there are these pixels in front so you cannot see clearly.
The effect is there even on a completely black screen.
The screen... -
by ChrissygizmoHello everyone, I’ve just been given a Samsung UE55JU6800K smart tv as it had white spots on the screen due to the led lenses falling off. After refitting them & putting the tv back together I thought it was a nice easy fix for a free bedroom tv , then I tried it before screwing the back into place. I realised that the right side of the screen was darker than the other side, I removed the screen again as I thought the backlights had failed but they are fine.
I put the screen back in place & turned it back on . The screen seemed to be ok again but different screens on the same... - Loading...
