Sharp Aquos 80" TV ~ Model # LC-80LE844U ~ Not operational
  • kca
    • Feb 2016
    • 548
    Re: Sharp Aquos 80" TV ~ Model # LC-80LE844U ~ Not operational
    Thank you, budm!
    Your insightful advice and clear-cut "know-how" were critical in the troubleshooting process. Amazing how you can isolate these problems with so few clues and from a distance. I speak for many when I say your dedication to these boards is both a lifeline of voltage ..... and an electronic godsend.
    ~ kca
    • kca
      • Feb 2016
      • 548
      This 80" Sharp Aquos Quattron 3D tv is still working flawlessly several days after the repair. Ordered the remote control and that should show up today. I want to get into the service menu and see how many hours it has on it. If anyone knows exactly how to do that with the remote in hand for these large, Sharp LCD tv's please let me know exactly what works. I found several different codes and sequences online and it will be easier just to jump to the one that definitively works.
      I want to take a moment to thank everyone who helped on this thread including. along with budm, budwich, R_J, and RJARRRPCGP. Hope I didn't miss anybody.
      ~ kca
      • CoppellTVRepair
        Sharp Aquos 80" TV ~ Model # LC-80LE844U ~ Not operational, Take 2
        by CoppellTVRepair
        There's a thread on the site titled "Sharp Aquos 80" TV ~ Model # LC-80LE844U ~ Not operational", detailing the process of the most common problem affecting power supply board PSD-0888D.
        For the sake of bringing something of value I'd also add (even though it probably belongs in the thread itself) that what's described there is one of the TWO possible variants of the failure - blown IC, blown fusable resistor 2.2 Ohm or 2 Ohm.
        The other is an internally failed, but not shorted IC, resulting in resistor that's still intact, but the board spontaneously losing power...
        12-02-2025, 06:25 PM
      • scubacamper
        Sharp Aquos LC-70C6400U Half Screen Dark
        by scubacamper
        I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
        Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
        when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
        05-03-2025, 12:19 PM
      • jonah1024
        Sharp Aquos LC-40UG7252E LCD TV burn in?
        by jonah1024
        Hello!
        I'm a few days old into this TV screens repair universe so please bear with me.
        Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
        - I did the classic unplug and hold power button to discharge the caps but it didn't help.
        - I did a factory reset as well...
        07-16-2024, 04:23 AM
      • corrize
        A funny fuse story – Lumix LX100 II
        by corrize
        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
        10-19-2023, 09:58 AM
      • klassic
        Sharp Aquos LC-60LE635E three blinks
        by klassic
        Hi community,
        I will describe my problem with a TV in those short following terms to be the most precise :
        What i have :
        power board DPS-162KP-1
        main logic board QPWBXF733WJN2
        symptoms :
        white led light logo at startup,
        after 2 minutes, blinking 3 times a row, repeating
        no backlight (and apparently no picture, checked panel with flashlight)
        no startup sound
        powerboard investigations :
        1-2 PNL : 0v
        3-4 GND
        5-6-7-8 UR : 13.15v
        9-10-11-12...
        10-24-2023, 01:39 PM
