High Res pictures download from ShopJimmy
    Are you able to download High Res pictures from ShopJimmy? I can only download low res now.
    Thanks.
  • R_J
    • 9629
    Re: High Res pictures download from ShopJimmy
    I am using an older firefox, I can save them using view page info, Media, and then pick the high res image and save as
    shopjimmy.com/samsung-bn44-00864a-f37ps_khs-power-supply-led-board
    • retiredcaps
      • Apr 2010
      • 9271
      If you right click on thumbnail and choose open link in new tab, I get hi res picture.
      I'm using brave which is based on chromium.
      --- begin sig file ---
      --- end sig file ---
        Woo Hooo, thanks! thanks! thanks!
        I use old FF as well but did not know about this function.
        I thought they blocking people from downloading high res since they update the web site last month.
        I use lots of pictures from SJ to help people troubleshooting the problems.
        Thanks RJ, you saved me.
        Hi retirecaps, I am not familiar with brave, I did not have the chance to play with Ubuntu yet. Thanks.
        • R_J
          • 9629
          I tried the, right click on the picture (small ones at the bottom) and "open link in new tab" and it also works, (easier) Then just save image as. This is in old firefox (52.9)
            I use the same FF, that works too.
            I use to be able to double-click on the small picture then it brings up the high res then I do save as, but now I cannot do that, now it bring up 'HOVER TO ZOOM'.
            Thanks for the tip!
            BTW, can you please look at this thread to see if you can help him out? I am really busy getting so many PM asking for help troubleshooting the problems, I almost stop replying to that thread due to BS from you know who. I may have to stop my PM.
            Thanks.
            • retiredcaps
              • Apr 2010
              • 9271
              Which thread?
                Sorry, it is this thread: https://www.badcaps.net/forum/showth...899#post982899
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Originally posted by budm
                  Well, it doesn't help that you were fighting a troll and helping someone who doesn't know basic electronic measurements.
                  The first I can't help with and hand holding the OP who wants step by step instructions is time consuming and tedious especially after the 100th or 1000th time.
                  I was going to report Diah to TopCat, but TopCat seems to know about Diah and warned him.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Brave works on Windows, Linux and Android.
                    I seem to switch browsers every 3 or 4 years. Nothing wrong with Firefox, but I find Brave a bit faster. I was using Google Chrome until recently when I switched to Brave.
                      by momaka
                      03-15-2023, 10:17 PM
                      Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                      by sam_sam_sam
                      I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                      I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                      I tested the battery cells there are installed right now and they are testing good with no issues that I...
                      02-04-2025, 08:08 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • DynaxSC
                      Extreme High Current & Low Voltage Short Killer ??
                      by DynaxSC
                      Hi Folks
                      I'm looking for a extreme high current short killer solution for a reasonable cost.
                      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                      After taking off the socket, the shorts dissappear again.
                      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                      10-15-2024, 10:13 AM
                    • harp
                      high voltage high resistance marking resistor
                      by harp
                      Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                      08-26-2024, 01:42 PM
