Hisense F42K20E static out of speakers even with sound turned down
  • jmandawg
    • Jul 2020
    • 42
    I found a Hisense F42K20E in the trash. The picture works great, but there's static coming out of both speakers even with sound turned down to zero.
    I'm attaching some pics. I'm not sure what happend to the main power board, it looks like crap.
  • petehall347
    • Jan 2015
    • 4429
    • United Kingdom
    Re: Hisense F42K20E static out of speakers even with sound turned down
    can you post a recording of the noise ?
    • jmandawg
      • Jul 2020
      • 42
      Here you go, i had to zip it to be able to attach it.
      • jmandawg
        • Jul 2020
        • 42
        Quick update, I just tested hooking a different speaker up to the output wire and i get the same static. The static also comes through the aux jack on the back of the TV.
        • budwich
          • Jul 2015
          • 3097
          what input are you using and what are you inputting? what aux jack are you referring to, the manual doesn't refer to one? You could try a factory reset to see if any thing changes. Plug in a headset and what happens to the speakers / what happens in the headset?
          what is the auto volume control set to?
          • jmandawg
            • Jul 2020
            • 42
            I'm using no input at all, absolutely nothing is plugged into the TV, it's just the blue screen, and that static sound is blasting out the speakers.
            I tried an hdmi souce, and it works, and i get the hdmi audio, but i also get the static.
            Sorry I meant headphone jack. If i plug headphones into the headphone jack, the speakers turn off as expected (no static out of external speakers) but the static comes through the headphones.
            I tried a factory reset, no difference.
            • budwich
              • Jul 2015
              • 3097
              Ok... thanks for the clarification. sounds like you lost a capacitor on the audio circuit.
              • jmandawg
                • Jul 2020
                • 42
                would that be on the main board or the power board?
                • budwich
                  • Jul 2015
                  • 3097
                  probably the main board since sound is made there... how ever it could be "dirty power" coming from the power but I doubt that because then you would like have other issues. If you post good medium close of the main board in and around where the speaker outputs are on the main (going to the internal speakers), someone may recognize some of the chips involved which may get you some "hints".
                    https://www.badcaps.net/forum/attach...4&d=1597787583
                    The Class D amplifier chip is in the bottom left of the board where the speakers connector is, you see 4 black round inductors to the left of the IC, and two Lytics caps to the right of the IC.
                    Does this TV have headphone output and if it does, do you get noise on the Headphone jack also?
                    • petehall347
                      • Jan 2015
                      • 4429
                      • United Kingdom
                      not familiar with that noise ... do you get normal audio over the top of it ?
                      • jmandawg
                        • Jul 2020
                        • 42
                        Yes it has a headphone jack on the bottom of the right side and yes it produces the same static. Here are some closer pics.
                        • jmandawg
                          • Jul 2020
                          • 42
                          Yes I also get normal audio out along with the static. The static is very loud so even at high volume you can still hear it
                          • CapLeaker
                            Leaking Member
                            • 8285
                            check all the other inputs and the tuner for the static noise. Maybe to a factory reset too.
                            • jmandawg
                              • Jul 2020
                              • 42
                              Yeah it's the same sound on all the inputs, in fact the sound does not stop even when switching input, it is constant. Also tried a factory reset and it didn't fix it.
                                Since the speakers has their own amplifiers to drive the speakers, the headphone also has its own amplifiers circuit, and both of them and both channels are making the same noise so it has to be something common to both of them.
                                Does the this TV have audio line outs through RCA jacks, try and see if the noise is there also.
                                How about when you set it to MUTE, does the noise go away?
                                • petehall347
                                  • Jan 2015
                                  • 4429
                                  • United Kingdom
                                  does the audio ic chip get hot ?
                                  on another note try disconnecting speakers and try headphones again .
                                  i am however thinking it could be a power supply issue .
                                  • Diah
                                    • Feb 2013
                                    • 6416
                                    this noise are static . it may caused by the dust (dirt you have on all boards) .first you need to clean all boards up and down sides. panel tabs ..sockets... with high pressure air
                                    • CapLeaker
                                      Leaking Member
                                      • 8285
                                      I there a input switching IC, or do all the inputs go to the main IC? IS the main IC something like MSD blah blah...
                                      • petehall347
                                        • Jan 2015
                                        • 4429
                                        • United Kingdom
                                        i noticed the noise has breaks like something is charging up then discharging then repeating etc etc .. could well well be corrosion or dust . as said above give it a good cleaning ..simple free things first . . i might scope the power supply or sub in a known clean supply for the audio .
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • Comp_Pro
                                          Macbook Air 820-00165 Static Chime Sound
                                          by Comp_Pro
                                          Hello all,
                                          I have a weird issue to solve here. This macbook air came in showing a black screen even though the backlight was lit. The display was not the issue as I tried another known good display. Upon trying to restart it, sometimes it boots up but freezes at the login page. More commonly however, the macbook will give the chime sound but then get stuck repeating the sound. The first chime sound is normal but the subsequent chimes sounds are crackly. Voltages seem normal, no liquid damage. I did find a blotch of something near one of the crystals on the other side of the CPU...
                                          11-02-2023, 03:23 PM
                                        • diggitt
                                          Radio, no stations, quiet static sound
                                          by diggitt
                                          I am repairing a DeWalt DC011 radio. I found that the secondary coil of the transformer had gone open circuit and the amplifier ic had shorted. I have replaced both but I can’t tune it in to a station and the static is very quiet. Any help is greatly appreciated. Thank you
                                          04-14-2025, 05:06 AM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:30 PM
