Rebooting tv, will not take firmware, tried changing the file name to upgrade_loader.pgk still will not take. Any other ideas?
Xbr65x900c
Re: Xbr65x900c
Sounds like a failure which will require the module to be serviced or replaced. If this is already a new module then follow the instructions in the video linked below:
https://youtu.be/3kYPjIHt8Lc
If you still have issues after following all the instructions then your module will most likely need to be serviced or replaced again.
It is possible to break your board if you do not perform the update/pairing properly. Follow instructions!
Good luck
