Re: Another KDL-40W600B
What says about 6 blinks? Is it backlight problem? If the update doesn't finish maybe the new main board is not the right replacement. It see a different partition structure or something else in software basis and it remain in an unespected end or dead rail..
Another KDL-40W600B
As of today the TV has been "updating" for some 20 hours. Stuck in a loop. I'm cautious that interrupting an update in "progress" is not a good idea. Suggestions?Leave a comment:
Progress, finally. I replaced the BAXL “main” board. Manual says you must update firmware after board replacement. For a day it just flashed red/green. Finally I used the remote sequence disp-5-Vol--power and got a brief input signal screen, then a 6-blink code. Read somewhere about how to force an update. Power disconnected, insert usb, connect power while holding chassis power button. Now it displays rotating arrows indicating update in progress. Leaving it to do it’s thing until tomorrow.Leave a comment:
Yes that is.the fuse... you have the service manual so check the correspondence of the fault and the blinking, 6 are the backlight, but 2 i don't remember, maybe again backlight.Leave a comment:
Here are some more photos.Attached Filesif you find these attachements useful please consider making a small donation to the site
Pictures are too blur and low res for me to zoom in to see the fuse.Leave a comment:
Here is a bigger photo of the fuse I asked about above. See the red outline.Attached Filesif you find these attachements useful please consider making a small donation to the site
Your photo's are too small to really see the point where your meter is connected.Leave a comment:
The replacement LD board appears to be working. After install I got two blinks fault code and the TV responded to remote input. It would not power on or turn on backlights though.
While checking fuses on the original main board (BAXL bd), I shorted pins at CN9101. Now F9101 looks open and the TV lost the blink code, so back to dead set.
Questions for the forum:
1. Could anyone confirm my probe is actually on F9101 in the third photo? Hard to tell with two smaller but identical components closer to the fuse legend.
2. Standby 3.3V is showing present at CN1001 pin 6 on the power board (LD) and at the corresponding pin at the main (BAXL), per my last photo. No fuses have 3.3V though. Can someone suggest a test point for it on the main and the tiny IR receiver board?
3. While the two-blink code was on, I attempted a firmware update and a hard reset, but got no response from the TV. I did confirm the remote operates another Sony TV. Any suggestions?Attached Filesif you find these attachements useful please consider making a small donation to the site
Another KDL-40W600B
I was just given this TV with an estimate invoice from the local TV repair. The TV tech wrote "power supply" on the ticket, but also wrote part numbers with prices for two unrelated parts, a main and a 51-pin LVDS cable.
The set is dead, which makes me question the need for any LVDS. With ohm checks, I determined that on the LD board a fuse (F1002) is open and its' load side reads 0 ohms to ground. This remains the case with cables disconnected. All the fuses on the BAXL "main" board read continuity and none show low resistance to ground.
Ebay has several LD boards to choose from, one new. So I'm waiting on a spare board.
Given the incredible miniaturization of components, I don't plan on trying to repair the bad board. I'm open to suggestions or willing to ship it to any recapper who would like to have a whack at it.
My thanks to the Badcaps member(s) who uploaded service manuals for the chassis, which I found by searching for the model number.
Link to board photos here:Last edited by steves7839; 08-07-2020, 06:49 PM.Tags: None
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
