Sony x930D , half screen grey bars
  • workingisgood
    • Jul 2020
    • 17
    Re: Sony x930D , half screen grey bars
    How long does it take to discharge the caps normally? A few hours or a day or so?
    • workingisgood
      • Jul 2020
      • 17
      Now I got capacitor anxiety
      • workingisgood
        • Jul 2020
        • 17
        If I just disconnect the board, and then mess with the tcon and disconnect the ribbon cables, do I even need to discharge that filter cap? I dont want to overcomplicate things here or burn some trace out trying to discharge it.
        • nomoresonys
          • 12331
          • U.S.
          No, it's ok to unhook the powerboard from the rest to clean tcon, just don't touch powerboard in those high voltage areas and unplug tv from power unless you are measuring voltage.
          • workingisgood
            • Jul 2020
            • 17
            Ordering elecrician gloves and plastic tools. I guess i'm just too paranoid.
            • nomoresonys
              • 12331
              • U.S.
              #26
              Very sensible to be cautious, after all you can't watch tv if your dead.
              • workingisgood
                • Jul 2020
                • 17
                It'll look like a hazmat operation to fix a t con board. Watch after all this, it be a bad panel. FML
                • workingisgood
                  • Jul 2020
                  • 17
                  Whats weird about this is no where on google can I find a similar picture of something happening. The whole right side just looks like a test pattern. All the panel failures look like small lines, and some look just plain garbled.
                  This is just like the whole right side is a test pattern, I mean I think its hardware but just a strange sorta thing going on.
                  • Daren87
                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                    by Daren87
                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                    08-13-2023, 03:25 PM
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • dvu0627
                    Sony XBR65X900H TV with Horizontal Lines right half of screen
                    by dvu0627
                    I have a Sony Smart TV XBR65X900H that started to have horizontal lines on the right side of the screen (see attached picture). When I played video on Youtube green horizontal line at regular intervals(1/4") across the screen.
                    I replaced the T-Con board but the lines are still there.
                    I believe this issue is from the Main Board. Before I replace the Main board, I wanted to seek advise if this is the problem from the Main board or something else?
                    Thank you for the help....
                    02-05-2023, 03:39 PM
                  • valvashon
                    LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                    by valvashon
                    The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                    Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                    11-24-2024, 12:08 PM
