SONY Bravia KD-55SD8505 Please HELP!
Re: SONY Bravia KD-55SD8505 Please HELP!
On my Ld board CN4001 when 2x blinking red, there voltages signals are:
1pin-0.0v
2pin-0.0v
3pin-0.0v
4pin-0.0v
5pin-0.0v
6pin-0.0v
7pin-0.0v
8pin-0.0v
9pin-0.0v
10pin-0.0v
11pin-0.0v
12pin-2.2v
13pin-0.0v
14pin-0.0v
15pin-0.0v
16pin-19.7v
17pin-0.0v
18pin-19.7v
19pin-19.7v
20pin-0.0v
21pin-19.7v
22pin-0.0v
23pin-0.0v
24pin-0.0v
25pin-0.0v
26pin-0.0v
27pin-0.0v
28pin-0.0v
29pin-0.0v
30pin-0.0vComment
can you post a picture of your power adapter showing the labeling?
Further, the list of measurements that you just posted, is that with the set flashing the 2 led blinks? Earlier, you say that there is no 3.3v... where exactly are you checking for this... ie. which connector and board? One other check, at the usb connector, check / measure voltages at all pins and list result.
Your pictures of the boards is very poorly lit... they don't have light bulbs in russia? :-)
Can post a good lit picture of the led driver board... use some extra lighting and turn your flash on your phone off.
The list of measurements appears to show a backlight error but the voltage seems a little off (2.2).Last edited by budwich; 08-05-2020, 06:36 AM.Comment
what do you mean by this "gave out sometime" where are you measuring these and when is this happening ... at the start of plugging in the power adapter, at the start of pushing power on, before led starts flashing 2 times?Comment
yes! when i flashed by usb,early tv is start but it for few minutes!and all the voltages are good for few minutesComment
please tell me what i gonna to do?
1.Chek voltages in all pin-outs of all boards in Stby mode?Yes/No
2.Chek voltages in all pin-outs of the all boards after pressing power on button?Yes/No
3.upload good foto of all boards?Yes/NoComment
I don't understand this... sorry. You put a usb drive with a new firmware in the usb socket and then powered up the set? At this point, set turns on for a bit? Is the usb being read?Comment
not so fast.... now that I understand that you say you can get a picture for a short time when you use a usb to try to flash firmware, you need to do that again and go back to post #65.... measure pin 12 at the time when you power the set up with the usb install and watch that value until you get the 2 red flashes.
Why are you saying it is an lcd panel problem? which cof/cog are you seeing is bad?Comment
Because the problem is in lcd panel AUO Optronics T550QVR05.0!When i got a picture for a short time when i use a usb to try to flash firmware,there is no picture!Only white screen with one vertical line and all CoF on panel is very hot!!not so fast.... now that I understand that you say you can get a picture for a short time when you use a usb to try to flash firmware, you need to do that again and go back to post #65.... measure pin 12 at the time when you power the set up with the usb install and watch that value until you get the 2 red flashes.
Have you got also gate CoFs? Which Cofs are hot , the source ones? In post 46 4th photo you see a testpoint named VSS1, check to which pin is connected of the tcon connector, then put a tiny piece of opaque adhesive tape on that pin to block it, do a tv test, if there is not picture then try the usb flash update, if the situation don't improves remove the stripe on that connector and put it on the same signal VSS1 on the opposite side.Last edited by Davi.p; 08-18-2020, 12:47 AM.Comment
Hello my friend!Thank you very much for helping,but i cant see testpoint named VSS1 on t-con board!please tell me what is the side of t-con i need to look (1 2 3)Have you got also gate CoFs? Which Cofs are hot , the source ones? In post 46 4th photo you see a testpoint named VSS1, check to which pin is connected of the tcon connector, then put a tiny piece of opaque adhesive tape on that pin to block it, do a tv test, if there is not picture then try the usb flash update, if the situation don't improves remove the stripe on that connector and put it on the same signal VSS1 on the opposite side.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi Guys.
I have this model in for repair at the minute, there firmware has failed and therefore keeps re booting, have tried all the usual reset procedures etc... and it tries to reset but goes straight back to the boot loop.
Does anybody know of a way to make it read from the usb so I can update the firmware? Any advice would be appreciated
ThanksComment
by JUCaESAlHola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television. -
by PopsCapsI have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
I do not hear any sound and I cannot see any backlight.
I have tried disconnecting every cable on each board one at a time to see if anything changes.
The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
My friend ordered another used power supply board but it is also doing the red indicator flash 3 times... -
by alegatorulsony bravia kdl-43w756c, no power, no sound
the charger brick has 19,2-19,3 vcc
changed the inverter board same result.
where should i start?
cheers -
by justin35Hello,
i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
from what i read online it looks to be an emmc issue…
i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
i took out the board and say an samsung 16gb emmc
i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
i could try to put one instead of the 16gb one, but will it work?
where do i get the software from?
any help will be much appreciated!...03-06-2024, 12:26 PM -
Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
Channel: Schematics and Boardviews
10-16-2024, 05:15 AM -
- Loading...
