40/233f bush tv powers on no backlight
  • petehall347
    • Jan 2015
    • 4450
    just got this in for repair .i suspect its the led,s . checked power at the 2 backlight connectors .one goes to about 130v then drops to 50v .the other stays at 0v . when i swap backlight plugs over the 130v/50v swaps sides and also the 0v .
    there is no flash . i was told the sound was out too .
    barring stripping the panel to test the led.s is there any other testing to do apart from buying a backlight tester ?
  • petehall347
    • Jan 2015
    • 4450
    Re: 40/233f bush tv powers on no backlight
    now looking at testers on that ebay and all the sellers appear to mostly same seller using different id.s ..its putting me off buying one there ..anyone have experience with ebay ones ?
    just looking at this one ..https://uk.rs-online.com/web/p/led-d...7442/?sra=pmpn
    no read out though so would have to add meters ..
      1) Can we see god clear pictures of what we are dealing with?
      2) It sounds like you have open circuit in the LED string, you have Voltage feeding the Anode of the LED string but you get 0V on the Cathode return of the LED string.
      3) The LED driver board is useless for testing the LED string, it use 5V USB power source and no boost converter. You need tester that can go up to 300V, the newer version of the LED tester can also drive the LED at much higher current than 30mA.
      4) Which LED tester on EBAY that you see?
      • petehall347
        • Jan 2015
        • 4450
        Originally posted by budm
        1)
        https://www.ebay.co.uk/itm/0-300V-Ou...UAAOSwmsxe8cqU
        • petehall347
          • Jan 2015
          • 4450
          looks pretty clear to me the board is working . just need to confirm with a good tester first before i attack the panel . i have a bad habit of fixing what isnt broken and breaking it .
            I bought SID GJ2C years ago.
            https://www.ebay.com/itm/LED-LCD-TV-.../373088668062?
            This new one claim higher drive current, not sure how true that is.
            https://www.ebay.com/itm/SFDER-0-300.../163748769335?
            https://www.ebay.com/itm/LED-Tester-.../273101005355?
            • petehall347
              • Jan 2015
              • 4450
              ordered one i posted before .
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Which one did you order?
                • petehall347
                  • Jan 2015
                  • 4450
                  https://www.ebay.co.uk/itm/0-300V-Ou...72.m2749.l2649
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    Im just getting back into tv repair this is the meter i was thinking of getting https://www.ebay.co.uk/itm/0-300V-Ul...y/272579531904
                    • petehall347
                      • Jan 2015
                      • 4450
                      i didnt see one with current as well as volts
                        Hi Vince, Please let us know how high of the current this meter can put out at high LED Voltage level when you test it out, thanks.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          yes i will do
                          • petehall347
                            • Jan 2015
                            • 4450
                            tester turned up today . tested led.s and they lit up from each plug .one is 3v ish different suggesting an led might have gone short .i can test again for exact figures ...strange thing is though i plugged the wires back in and the back-lights are now working .
                            i looked for a back-light setting and could only find brightness which i dont think affects back-lights so the setting might be done in service mode ?
                            • petehall347
                              • Jan 2015
                              • 4450
                              i dont get it ..both plugs now measure 60v with tv working them ... and both 53v running off the tester . all seems fine . am going to run it a few hours and see what happens ...
                              looks to me like the tester fixed them somehow ...
                                May be bad connectors between the strips.
                                • petehall347
                                  • Jan 2015
                                  • 4450
                                  that did cross my mind . what i have done is left in in standby overnight .am going to run it a few hours tomorrow then put all the screws back then run it again a couple of hours .if still ok give back to the owner and see what happens . right now i cant fix it because it isnt broken .
                                  • petehall347
                                    • Jan 2015
                                    • 4450
                                    well its still working for the owner
                                    • JaquesPratt
                                      Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                      by JaquesPratt
                                      I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                      This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                      07-16-2024, 01:04 AM
                                    • triplefour
                                      TCL 75S421 has sound but no backlight not even a flash
                                      by triplefour
                                      TCL 75S421
                                      PSU BOARD: 40-L402H8-PWD1CG
                                      it shows not even a flash of backlight when powering up.
                                      but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                                      testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                                      unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                                      i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                                      with mb connected, PSON...
                                      11-17-2023, 09:54 PM
                                    • DanPoka
                                      by DanPoka
                                      02-15-2025, 05:05 AM
                                    • Comp_Pro
                                      No Backlight Macbook A1990 820-01041
                                      by Comp_Pro
                                      Hello all,
                                      Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                      Tests performed:
                                      There is no backlight even with a good screen.
                                      Backlight IC is receiving the correct support voltages.
                                      Fuse F8400 ok
                                      Current sense resistor R8400 ok
                                      Backlight IC is receiving 3.3V on enable pin.
                                      Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                      Backlight IC receiving 5V from PP5V_G3S
                                      Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                      I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                      05-06-2024, 10:23 PM
                                    • cheebster
                                      iPad Pro 12.9 5th Gen Backlight Issue
                                      by cheebster
                                      Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                      Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                      Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                      The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                      Anyone...
                                      05-20-2025, 09:17 AM
