Sony kdl-48r550c -vertical and horizontal lines!
  • kgavionics
    • Apr 2017
    • 152
    Hello guys
    I got this Sony kdl-48r550c which has vertical and horizontal lines (see picture below)
    I disconnected the ribbon cable from both the Tcon board and main board and the lines disappeared completely which in my opinion indicates that the panel is still good!
    Is anybody have any idea what could be the next step to troubleshoot this tv?
    Thanks in advance guys!
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sony kdl-48r550c -vertical and horizontal lines!
    I think the problem is with the panel. Most of those lines appear to follow the OSD.
    • budwich
      • Jul 2015
      • 3097
      it would appear to be a "panel problem" as in "things associated with the panel that can't be readily card replaced" because it appears that the set has an integrated tcon / driver board which is attached to the panel. You might get lucky by checking some of the smd components on the driver boards to see if they are shorted. These might be component level replaceable withe careful soldering.
        +1
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4464
          • Italy - Milan
          That photo of the screen is not enough to.evaluate, i think if it is so hard to put a source on the board, so we can't play lottery..
          • noisykid
            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
            by noisykid
            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
            12-30-2024, 07:15 PM
          • visionbluedemon
            Help. Sony kd-65x85dj vertical lines
            by visionbluedemon
            First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
            Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
            tried blocking LC lines too, but same results
            is it lcd panel issue or tcon board issue?...
            07-25-2025, 04:56 AM
          • gpo23
            Sony KDL-40V3000 - Vertical lines
            by gpo23
            i order a t-con because i had bad colors on my SONY KDL-40V3000 :
            With the new t-con the color are good but there are vertical lines on all the screen :
            I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
            Is there a way to fix the vertical lines on the new t-con ?
            Thank you for your help
            gpo23...
            10-04-2023, 09:11 AM
          • ggil44
            Sony XBR-65X750D Horizontal lines bottom of screen
            by ggil44
            Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
            05-30-2023, 07:51 PM
          • Stanley1843
            by Stanley1843
            06-29-2024, 11:54 AM
