Sony KLV32U300A power on/off with 2 times blinking led
    Re: Sony KLV32U300A power on/off with 2 times blinking led
    Originally posted by Admirality
    Hi i just would like to find out if the regulator voltages are correct so if anybody could please give me info i will be grateful
    INH=5.78v
    I=5.78v
    O=5.06v
    A=1.22v
    LD29150 adjustable low drop out regulator with controlled pin. It is working fine putting out 5.06V.
    Did you look at the main board schematic to see the P/N and what the output Voltage should be for that IC210? Please spend times look at it.
    I still need to reformat your readings on the connector to make it easier to see what they have and do not have.
    • Admirality
      • May 2020
      • 80
      • South Africa
      Thanks budm
      • YasaCh
        Sony kdl 40p5500 red light keeps blinking 3 times
        by YasaCh
        Hello...
        my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
        i opened the back cover no sign of damage on the powery suply or motherboard
        when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
        another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
        07-07-2025, 11:53 AM
      • NolesFan
        Sony kd-85x85j LED blinking red 6 times
        by NolesFan
        I know the 6 blinks are a backlighting issue, but when I pulled off the back cover and turn it on, the is a white flash from with the panel then I hear what sounds like a relay trip and the TV goes into the 6 blinking light code. Before I pull all the electronics off and checking the individual strips, there is a on the power board, a harness with 4 wires that run thru the panel, which are what I believe are the LED lines, but Im not a tech so no clue. Wires read OUT 1 + & - and OUT 2 + & - My first inclination was to remove the power board and use my LED tester and go to each + &...
        03-16-2025, 11:50 AM
      • androripara
        Sony Bravia 55HX820 - 4 times blinking red standby led
        by androripara
        i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
        I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
        Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
        10-19-2023, 05:16 AM
      • ahmarzo
        Hp 15-cs laptop 5 times dc jack blinking white
        by ahmarzo
        I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
        First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
        Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
        But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
        12-28-2024, 04:46 AM
      • shahnld
        Sony kdl 65xg9505 green amber blinking
        by shahnld
        Good Day.
        I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
        i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
        green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
        01-03-2024, 03:05 PM
