TCL U65E5800FS Is this LED issue?
  • RooTV
    • Apr 2020
    • 128
    I have discussed this in another thread but have started this one to hopefully catch the eye of someone who has seen this actual model - TCL U65E5800FS
    I am wondering if this could be a led issue, as the tv's I have worked on before that have had led issues only did the flash and no picture type thing?
    This tv appears to have 2 strips out (see pics) and still lights up. Could it be a different issue?
    Also, if anyone has worked on this model tv, do the strips run vertically on this model? i havent seen one that runs vertically yet, but the pictures sure look like it does?
    I havent been able to find the part number for the led strips either. There doesnt seem to be much info on it anywhere. I will have to check the panel model and try to get the led from that I think.
    Thanks for any help.
    • 12276
    • U.S.
    Re: TCL U65E5800FS Is this LED issue?
    Oh NOOO you didn't pull a double thread, that just confuses things and makes it just that much harder to get a solve, as you can see, every time you post on your thread it moves up, so there's NO need to double thread.
    • RooTV
      • Apr 2020
      • 128
      My bad.
      I was just trying to get more concentrated response on this model. I thought it would make it easier with the brand and model in the title.
      I can't delete it now
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        🛠 Original Issue
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • ugamazing
        by ugamazing
        12-17-2024, 07:05 PM
      • shahnld
        Lenovo legion 5 pro startup issue
        by shahnld
        Good day Experts
        I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
        A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
        And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
        08-24-2025, 12:31 PM
      • ahmarzo
        Acer laptop battery draining issue
        by ahmarzo
        Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
        Help me to diagnose this issue as there is no shortage in the inputs MOSFET
        08-02-2025, 06:39 AM
