Samsung One Connect Box need help identifying missing IC.
  • fonogroove
    • Feb 2017
    • 7
    OCB model BN94-07414Q, component location is IC3601, directly under OCB port(CN3301). Marking on chip was completely unrecognizable, so needed to ask here anyways, upon removal don't know where it fell. If anyone knows the identity of this IC, been Surfing the net for months now to find a picture close enough to see the marking but pictures posted are too blurry. Let me know of any info I left out that might help. Thank you.
  • retel
    • Mar 2015
    • England
    Re: Samsung One Connect Box need help identifying missing IC.
    I've attached a photo of the part from one I've here, it seems to say AFD , the D looks more like a backwards C though.
    Sorry I can't get a better picture of it.
    Hope this helps.
    • fonogroove
      • Feb 2017
      • 7
      You are awesome!!!!! Thank you, very much appreciated. Picture is good
      • fonogroove
        • Feb 2017
        • 7
        @retel Thanks again. Found out the "backwards C" is actually a mark that belongs to ON Semiconductor. It's an ON Semiconductor SPDT RON Analog Switch NLASB3157DFT2.(<---highlight, right click that part and search) It still has the "AF" but with an M(date code). I surfed over to their website, then scrolled all the way down to click on Contact Us and under Technical Support I emailed them a question with the pic you sent me. I was surprised they responded with a link to their part, that was totally cool! Thanks again.
          09-07-2024, 05:50 AM
        • KYBOSH
          Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
          by KYBOSH
          I picked this one up today.
          Previous owner says no signs of life.
          TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
          Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
          The TV model is QN65LS03BAFXZA - version: CB06
          The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
          I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
          Will keep you all...
          04-05-2025, 08:32 PM
        • atkallu
          Samsung One Connect Box SOC1001N vs SOC1004N
          by atkallu
          I am asking have somebody information about Samsung one Connect boxes compatibility ?
          So, can I use SOC1001N box on the TV which have SOC1004N box, is it compatible ?
          SOC1001N box has been worked with Samsung QE55Q8 and the SOC1004N box has been used with Samsung QE55Q9.
          Boxes part numbers are the same: BN68-08730A-00.
          07-09-2025, 01:54 PM
        • An-klamm
          Samsung 55HU8590 UE55HU8590 maybe one connect box ocb
          by An-klamm
          Hello!
          I have a TV that I can't get any further with.
          It is a Samsung UE 55HU8590 with one connect box.
          When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
          As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
          Since the TV works without ocb, I assume that it can't be the PSU?!
          I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
          Is there...
          12-04-2023, 01:35 AM
        • nader_guesmi
          Samsung UE65TU7172 – BN41-02751C – CI+ ECP Keys Missing / Digi Card Not Working
          by nader_guesmi
          Hey everyone,
          I’m working on a Samsung UE65TU7172 with mainboard BN41-02751C. The TV powers on normally, I’ve applied the latest software update, and all measured voltages are correct.
          Problem: The CI+ module doesn’t read the Digi card.
          I accessed the service menu (using Mute + 2 + 4 + 7 + Exit) and ran the CI+ test. The results show:
          • CI+ production keys: Success
          • ECP keys: Not installed
          So the TV doesn’t even attempt to communicate with the CAM/card.
          I’ve tried multiple Digi cards (both old and new), and they work fine on another...
          09-09-2025, 03:04 PM
