Sony kd 43w8307c stuck in screen test mode.
  • vikivng
    • Feb 2019
    • 216
    Re: Sony kd 43w8307c stuck in screen test mode.
    Yes,
    the cables certainly look suspect.
    I have never encountered this connector before.
    Can someone advise me on how to remove this.?
    • vikivng
      • Feb 2019
      • 216
      Bigger image.thnx
      guess not lol
      • budwich
        • Jul 2015
        • 3097
        big time ugly... that looks like some form of water ingression / contamination. hopefully, it can be cleaned / checked.
        iirc, you press down in the middle section which causes the outer two edge points to lift a bit. Hopefully, someone will know for sure. Don't force things though as finding replacement cables can be tough.
        • vikivng
          • Feb 2019
          • 216
          Thnx bud,
          I have already found the cables.Just need to make sure these are beyond
          repair.
          Yes,,I will not even touch the connector unless I know how it works.
          I will wait for someone to be sure .thnx,
          • vikivng
            • Feb 2019
            • 216
            Anyone else knows how to disconnect these??
              • 12116
              • U.S.
              #26
              Looks similar to this if it is it will come out easily never force it: https://www.youtube.com/watch?v=_VB1qdpOc-E
              • vikivng
                • Feb 2019
                • 216
                #27
                yes,pressing the cntre allows the cable to slide out.
                Both cables loss of connection.
                • budwich
                  • Jul 2015
                  • 3097
                  I hope this means you have the new cables ready. Depending on how bad the old ones are, you might just consider tossing them... just in case playing with them any more might take out either the tcon or main board.
                  • vikivng
                    • Feb 2019
                    • 216
                    #29
                    Hi bud,
                    yes I expect the replacements tomoro to arrive.
                    It must have been corrosion as I didnt see anything odd under the micro.
                    Tv powered on with no cables shows this cycling as well ..So most likely was the issue.
                    I will update once they arrive.
                    • brucetv
                      • May 2015
                      • 281
                      • united states
                      #30
                      By looking at the middle of that connector it looked like it shorted, arced, and burnt through the white plastic release. You might have to replace the main and the cable.
                      • vikivng
                        • Feb 2019
                        • 216
                        #31
                        Hi guys
                        update on this.
                        replacement Cables were installed .
                        The indicator led then went from green alternating to yellow and the same intro music being played but NO backlights!!!
                        I then inserted the USB with the update.
                        This time the USB light blinked for a much longer time than the previously attempted update.
                        But then after approx one minute,the mainboard light went out.
                        Now the indicator led is flashing white .
                        • vikivng
                          • Feb 2019
                          • 216
                          #32
                          thnx bruce.yes I think you are right
                          • vikivng
                            • Feb 2019
                            • 216
                            #33
                            Getting 0v on the mainboard side PWRON
                            • vikivng
                              • Feb 2019
                              • 216
                              #34
                              bruce
                              upon closer inspection of that connector,that black soot mark rubs off so no damage to the connector.
                              No damage to the plastic that would indicate heat of any kind.
                              • Ryan.man
                                by Ryan.man
                                02-04-2025, 12:23 PM
                              • YellowJacket
                                SHARP LC-32CHF5111K - stuck at color test mode
                                by YellowJacket
                                Hi friends,
                                TV has stuck at - as I googled the term - color test mode. Slowly flashing colors white, red, green, blue, black, over and over again. I tried some hints from internet, like pressing some remote buttons, but nothing worked. I also tried factory reset for Sharp TVs => "while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan- " , but TV doesn't even start during buttons pressed.
                                So I decided to flash new firmware to SPI ROM. What do you say, would it help? If so, where can I find some dump? I was unable to find...
                                02-04-2023, 03:11 AM
                              • BMCappelletti
                                Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                                by BMCappelletti
                                Hi everyone.
                                Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                                Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                                Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                                02-18-2025, 12:22 PM
                              • gigigi
                                Panasonic tx-55cx802b stuck on panel test mode
                                by gigigi
                                Panasonic tx-55cx802b stuck on panel test mode.
                                It was working normally but few days ago some of the LED reflectors fall off.
                                I've opened it up carefully, re-glued, while it was open switched it on to test LEDs.
                                Then carefully assembled back.
                                After plugging in to power remote does not work.
                                Using power button on the TV it turns on but gets itself into a panel testing mode: white, gradient, red, gradient, blue, gradient, green and so on switching between colours.
                                Anyone knows how to get out of this panel testing mode?
                                I've tried so...
                                06-20-2021, 07:06 AM
                              • modtool
                                HP x360 Chromebook 14A-CA, DA00GIMB6H0 REV:H, flooded, restored, slow and stuck in tablet mode
                                by modtool
                                Dear colleagues,
                                I've entered the repair of the chromebook machines just one month ago and I've found some significant differences from the classic laptops or macbooks, so I'm searching some advices.
                                The owner of this chromebook gave it to me after it has been left flooded by water for almost a week, so chances of repair were not so high, the mainboard was oxidyzed in many spots but I made a nice cleaning, resoldering and component replaging work and now it is almost working.
                                Among other things I've cleaned many spots from oxyds, reballed CPU, EMMC, EC, replaced...
                                05-07-2025, 06:10 AM
