Sanyo RFWZV475F DVD Recorder/VCR Combo Turning off when loading tape
  • Bangulo
    • Jun 2013
    • 21
    I have this sanyo VCR/DVD combo when i first got it the tape would drag really slow. this is a video of it
    https://youtu.be/3XrioZgPI_k
    I got busy during this time and it has just sat in my room for two years and now i've been trying to get around fixing it. Well now it wont even play the tape and just powers off upon loading the tape here it is at its current state
    https://youtu.be/zynEh0xVsNM
    I am pretty much stuck at this point on what to do. I took it apart and cleaned the encoder mode switch! Which did nothing. So i thought maybe the power supply was bad and i completely recapped most of the power supply. as ive seen other videos with this similar unit have bad caps. i missed four caps that i some how forgot when i was ordering caps
    I also cleaned the little RF glass signal thing that gets split three ways. I don't know the proper name but the RF sensor that detects if the tape is spinning.
    This unit is amazingly clean inside it was manufactured in 2015 i got in 2018 so it has seen very little play! Ive noticed that this type of machine is made by MAGNAVOX ZV427MG9 A and i am sure there are other machines from looking at youtube videos.
    Any help of suggestions would be great! sorry for the huge post but i've been slamming my head on this thing for a few days now.
    I should also add that the capstan moves freely when i move it with my hand and it spins all the gears!
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Sanyo RFWZV475F DVD Recorder/VCR Combo Turning off when loading tape
    Have you watched any of daves videos on youtube
    https://www.youtube.com/user/ATVVideoProductions
    • Bangulo
      • Jun 2013
      • 21
      I did! Thats where i got the idea to clean the encoder switch.
      • R_J
        • 9588
        In the first video was the sound coming fom the smps section? it sounds to me like the power supply was having an issue, I have heard that sound before, noisy smps. In the second video it could be that stray light is tirpping the tape end sensor, place something over the vcr to stop light shining on the sensors.
        • Bangulo
          • Jun 2013
          • 21
          I am not actually sure what "SMP" means, I mostly dabble in fixing video game units and computers. So allot of this is new to me sorry for dumb questions. That sound is definitely coming from where the tape spools up around the drum if that helps. I'll also try your suggestion with covering up the sensor.
          • Bangulo
            • Jun 2013
            • 21
            So i reopened it up and re cleaned the encoder chip just make sure! this time i cleaned it with some contact cleaner. Still no luck. It seems to power off as soon as the arms move to feed the tape onto the hub. Before it even tries to play the tape.
            • vinceroger69
              • Mar 2012
              • 6714
              smp (switch mode power supply) did you get the timming marks re aligned when you removed the mode switch etc its usually little dots or triangles marked on the cogs
              • Bangulo
                • Jun 2013
                • 21
                Yeah i got the timing aligned. It was doing this exact behavior before i even touched it. Yeah the sound is not coming from the power supply, I wish it was then id probably have had this sorted lol!
                Thanks for the suggestions though! appreciate it!
                • R_J
                  • 9588
                  You must have done something to it because it was loading and playing (with the erratic capstan) before in the first video and now it is no longer loading the tape. Check that any mechanism to board plugs are not damaged.
                  • Bangulo
                    • Jun 2013
                    • 21
                    Only difference from the first video and second video was time. it sat for two years then when i plugged it in thats what it did last week. This is why i am lost on what to do at this point. I am ordering the rest of the caps to finish off the rest of the power board just in case it is a slight chance that it may be due to the caps i missed. checking voltages and connections would be my next step i guess. these things are built like junk all the wiring is junky soldered down flimsy ZIF ribbon cable even the power cable is ZIF
                    • R_J
                      • 9588
                      When replacing the caps in the power supply, make sure to replace the small electrolytics in the primary circuit, usually around 1~10µf/50v, they can dry out and cause unstable problems. Post some pictures.
                      I thought the second video was after the mode switch cleaning not two years later.
                      • Bangulo
                        • Jun 2013
                        • 21
                        Them really small caps are the ones i missed so it would be nice if thats it lol
                        No worrys about the second video! Any suggestion is appreciated! Ill post some pictures tomorrow of what i capped so far. and the boards.
                        • Bangulo
                          • Jun 2013
                          • 21
                          So i made a little bit of progress, I got it to actually play a tape without turning off. What i did was engage the capstan to the pinch roller manually by pulling the loading belt till it fully engaged and then i moved the roller well it was off. I saw someone do this and it fixed his vcr on accident were i got the idea to begin with.
                          But now it seems to me that it may be a bearing in the capstan motor thats messed up
                          Here are some videos of what its doing. All the noise is coming from the motor. When i put pressure on the capstan the sound goes silent and when i let go it continue. Also no amount of pressure really seems to slow the motor down but when i let go it seems to fluctuate.
                          Here are some videos of the behavior
                          https://youtu.be/Vd48QHHGpGY
                          https://www.youtube.com/watch?v=X0uKO_hzyLc
                          • R_J
                            • 9588
                            So what you are saying is the loading belt is slipping and not loading the tape all the way.
                            I doubt the problem is with the capstan motor/bearing itself, the bearings rarely wear out because it does'nt spin very fast. It could be caused by a poor supply voltage to the motor drive circuit, this is a multi phase motor and if the drive waveform is not correct it won't operate smoothly.
                            • UNITRAX
                              Radio tape recorder Hitachi TRK 8010k - How to install aux in place of am band?
                              by UNITRAX
                              Hitachi TRK 8010k
                              Is it possible to have an aux input in place of the radio on the am band range? When connecting to the tape recorder, I have additional tape noise. There is an integrated circuit HA11251 in the schematic. Which pin is the am radio output on?
                              Radio tape recorder diagrams and HA11251 datasheet included...
                              02-18-2023, 07:23 AM
                            • RetroComputingGrotto
                              IBM LTO 7 Tape Drive - Dust Sensors??
                              by RetroComputingGrotto
                              I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                              I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                              09-19-2024, 01:54 AM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • netgearnetgear
                              JVC 40" LED TV (LT-40KC385) - Turning ON sometimes (stuck on loading, menu etc.)
                              by netgearnetgear
                              Hello esteem members,
                              I have a JVC Television that fails to turn ON sometimes. The stand-by red light is always on. When the TV turns on the the JVC logo displays then the TV attempts to scan for local channels...it then freezes. If I unplug it, then it refuses to turn on - stand by light on. The power supply input voltages are present - 12V, with the backlight 0.32V when the TV refuses to turn on. Backlight voltage is 2.98V when TV does turns ON. All regulator chip has 3.3V on pin 8. Processor voltage - 1.02V, Ram - 1.5V. I am thinking about reflowing the on-board RAM. When the TV was...
                              10-28-2023, 06:59 PM
                            • triplefour
                              LG 75UN8570AUD panel issue fixed with tape.
                              by triplefour
                              I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                              add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                              07-17-2023, 10:22 PM
