USB not working
  • ageman
    • Oct 2015
    • 45
    • united kingdom
    USB not working
    Hi Guys
    does anybody have a service manual or schematic diagram for a samsung HG40EA670 TV.
    The USB port isn't working and I am trying to identify some surface mount components.
    Cheers all
    Adrian
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: USB not working
    Have you got +5V supply at the USB pinout
    • ageman
      • Oct 2015
      • 45
      • united kingdom
      Re: USB not working
      Hi dick_barton.
      Thanks for your question, no I do not have 5 volts. There is a surface mount device see attachment, this is where the 5 volt comes from. It is marked BS5, but cannot find this online, this was the reason for a schematic diagram.
      Any ideas what this chip is?
      Adrian
        Re: USB not working
        Please provide straight shot pictures that show more area of the board around the USB port and the whole top side of the board
        • ageman
          • Oct 2015
          • 45
          • united kingdom
          Re: USB not working
          Hi budm
          have attached photos
          thanks
          Adrian
            Re: USB not working
            1) What DC V do you get on both ends of C1501, 1505 with ref to GND?
            2) What DC V do you get on both ends of L1501 with ref to GND?
            3) What DC V do you get on both pin 2 of IC1501 with ref to GND?
            • ageman
              • Oct 2015
              • 45
              • united kingdom
              Re: USB not working
              Hi budm
              1) -1.5 volts and dropping C1501 and C1505 joined together at top.
              C1501 bottom 5.2 volts
              C1505 bottom 0.0 volts
              2)L1501 0.005 volts both sides.
              3) IC1501 pin 2 to ground Middle pin bottom to ground 3.3 volts
              Adrian
                Re: USB not working
                Originally posted by ageman
                Hi budm
                Adrian
                OK, so it looks like pin 4 of IC1501 is the 5V input. Pin 5 of the IC1501 looks to be the output pin which then goes to the USB VCC pin via L1501. Pin 2 of the IC1501 looks to be the control pin to turn on IC1501, so far I cannot find any info on this IC1501. I look at some Samsung main board schematic to see if some of them may use the same IC then we can figure out the circuit. That Pin 2 may be Active LO, <1V = ON.
                • ageman
                  • Oct 2015
                  • 45
                  • united kingdom
                  Re: USB not working
                  OK budm
                  Thank you
                  Adrian
                    Re: USB not working
                    BTW, can you check the resistance between either end of inductor L1501 and GND?
                    Also if you plug in USB device, do you get any Voltage on L1501?
                    • ageman
                      • Oct 2015
                      • 45
                      • united kingdom
                      Re: USB not working
                      Both sides of the inductor goes up to 396 Kohms assume there must be a capacitor charging.
                      No voltage if I plug in a usb stick on L1501
                      Cheers
                      Adrian
                        Re: USB not working
                        OK, I found the info after lots of searching:
                        https://monitor.net.ru/forum/threads/558779/
                        IC1501 is RT8016L 1.5MHz, 600mA, High Efficiency PWM Step-Down DC/DC
                        Converter
                        https://cdn.badcaps-static.com/pdfs/...f042df7b46.pdf
                        • budwich
                          • Jul 2015
                          • 3097
                          Re: USB not working
                          great find.... I had opened up tablet with an issue with the USB. Similar chip "type" and couldn't find anything and ultimately replaced the main board. The problem I see is that people plug various usb things into the connector without realizing / knowing what power consumption the item has. It appears from the spec, that it is very limited and I bet there isn't any circuit design protection on the card and thus this component fails and is hard to find because of markings and otherwise. Again, great find.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Re: USB not working
                            Excellent find Budm
                            • ageman
                              • Oct 2015
                              • 45
                              • united kingdom
                              Re: USB not working
                              Thanks Guys for your help.Will replace, and let you know if successful. Got to wait up to 30 days for delivery of said item
                              Cheers
                              Adrian
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Re: USB not working
                                I would check all the voltages at the pins1 to 8 of the IC especially the Enable input (Pin 2) which should be a minimum of 1.5V to enable the IC to switch on.
                                I think it's worth checking all while waiting for the replacement.
