SONY LED TV BAL board Throubleshooting
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • huj3r
    Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
    by huj3r
    Hi there!
    I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
    Photo of the situation after the black shadow dissipates:
    After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
    I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
    > This indicates HFR Communication error. [ HFR Communication...
    08-15-2023, 10:55 AM
  • cheeky2
    Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
    by cheeky2
    For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
    See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
    01-08-2024, 05:56 AM
  • picouser
    Please help indentify the chip on Sony WH-1000XM4 battery board
    by picouser
    My Sony headphone WH-1000XM4 is damaged by water, and the chip circled is totally ruined. I found this photo by Google but can not read it. By any chance someone here know what chip it is? Thanks in advance!
    01-16-2024, 09:35 AM
