lnt5265fx/xaa few vertical lines?
+ More Options
Posts
  • kgavionics
    • Apr 2017
    • 152
    Hi
    I have a lnt5265fx/xaa LCD , i bought it for cheap 2 years ago, because it has some colored lines in the left hand side which disappear completely after about 15 min after i turn on the TV.
    Since a few days, when i turn on the TV and wait about 15 min, the lines disappear except one single green line remains.
    To be honest, it's not much of a problem, because the TV is still watchable, but since i have a spare time , i though i would fix it!
    I think Tcon left ribbon cable might be the culprit, but i wanted to have some input from you guys,before i go ahead with my troubleshooting!
    thank you in advance
    • 12206
    • U.S.
    Re: lnt5265fx/xaa few vertical lines?
    Clean them and make sure they are aligned correctly, can use isopropyl alcohol and a q-tip, not too vigorous they can be delicate, good place to start.
      1) What is the brand of this TV?
      2) Attach good clear pictures of the whole backside of the TV showing all the boards.
      3) Attach the screenshot of the screen showing the problem.
      • neilc6
        • Nov 2015
        • 1550
        TV is a very old Samsung LCD. Model numbers LNS (2006) and LNT (2007). Vertical lines are panel problems and possibly bad TAB bonds. Time to retire it.
          • 12206
          • U.S.
          One way to find about tabs, strip it down to the tabs and inspect them, try light pressure from the top and see if display clears up, "shim" method may work if that's the issue, many many videos on youtube covering this issue.
          • kgavionics
            • Apr 2017
            • 152
            Sorry for the late update, I've been working on another TV.
            Cleaning the tabs didn't fix the problem.I also went ahead and checked all the Aluminum caps on the main-board, found few caps with a slightly higher ESR, replaced them, but still i have the same problem.I'm running out of ideas regarding this problem!I think i'm gonna sell it as it is!
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4353
              • Italy - Milan
              insert a metal shim under the cof chip, with a toothpick touch along the chip soldering area, when you found the critical point use the soldering iron to warm that point, at sequential step each time more prolongued, when you are doing watch the results on the image.
              • kgavionics
                • Apr 2017
                • 152
                Is the cof chip, the main chip on the T-con board?
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4353
                  • Italy - Milan
                  is the chip on the tab, search the web..
                  • kgavionics
                    • Apr 2017
                    • 152
                    ok thanks!
                    • Stanley1843
                      by Stanley1843
                      06-29-2024, 11:54 AM
                    • Falki
                      Colorful LCD Vertical Lines on Samsung ue55es8090
                      by Falki
                      Hello there, ive recently found an older 55inch Samsung SmartTV.
                      A similar issue has been posted as well but also with no actual response ...
                      08-12-2025, 04:19 AM
                    • visionbluedemon
                      Help. Sony kd-65x85dj vertical lines
                      by visionbluedemon
                      First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                      Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                      tried blocking LC lines too, but same results
                      is it lcd panel issue or tcon board issue?...
                      07-25-2025, 04:56 AM
                    • gpo23
                      Sony KDL-40V3000 - Vertical lines
                      by gpo23
                      i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                      With the new t-con the color are good but there are vertical lines on all the screen :
                      I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                      Is there a way to fix the vertical lines on the new t-con ?
                      Thank you for your help
                      gpo23...
                      10-04-2023, 09:11 AM
                    • Firentiosi
                      1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                      by Firentiosi
                      Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                      The issues are as follows: the...
                      11-27-2024, 12:33 AM
