Vizio M60-C3 won't turn on. Is it the main board?
  • afdreher
    • May 2020
    • 4
    Hi, I've been stalking the site trying to diagnose the problem with my Vizio M60-C3. When turned on, the screen remains black and there is no audio. There is nothing displayed on the screen using the flashlight test, but the status light does illuminate and the optical audio out port does illuminate. The symptoms are almost identical to https://www.badcaps.net/forum/showthread.php?t=51443.
    On the power supply board (60CAP090), with the TV off, everything reads ~0V except for the two +12V rails (pins 8 & 9 on the connector the main board (CN201)), which read 12.57V, and the AC-DET (pin 12), which reads 3.79V.
    When I press the on switch, the status light illuminates and then starts to flash, indicating some kind of problem.
    On the connector to the LED driver board (CN301) top right connector on the power supply board), the X00020 pins (pins 3-8) read 26.48V, and the pin labeled VSNS changes from 0V to 2.45V. Pin 12 stays at 0V. So the power supply is providing 24V power to the drivers.
    On the connector to the main board (CN201), the T CON ON (pin 15) and 12V T CON (pin 14) both remain at 0. Likewise, the power supply provides 0V to the T CON board through pins 1-4 on the connector at the top left (CN202). The 12V rails (pins 8 & 9) remain ~12.55V. The 12V-AU (pin 4) gets activated to 12.55V, although no audio is produced. The PS-ON (pin 3) signal is provided from the main board at 5.12V, and the AC-DET (pin 2) stays at 3.77V.
    On the LED driver board, the power feeds in at 26V through CN102. All of the pins for the CN101, which I believe from reading through the other posts is the BL-ON signal, read 0V.
    There aren't any obviously blown connections, FETs, or capacitors on any of the boards.
    I'm guessing this is a main board problem because there isn't a signal telling the T CON and BL to activate. Am I correct? Is there something else I should check before I try to hunt down a new main?
    Thanks so much!
  • neilc6
    • Nov 2015
    • 1550
    Re: Vizio M60-C3 won't turn on. Is it the main board?
    Most likely bad bga connections on the processor of the main board. Symptom is ON/OFF or BL_ON pin not going high (>2.5V) when the tv is turned on. A few threads if you search your model or M43-C1
    • afdreher
      • May 2020
      • 4
      Thanks, I'll have a look for those. Most of the previous threads didn't make a whole lot of sense to me principally because Vizio's boards are rather poorly labeled.
      • budwich
        • Jul 2015
        • 3097
        what does this mean... "There aren't any obviously blown connections, FETs, or capacitors on any of the boards"... you checked all of the fets with a meter or you used your eyes as "visual confirmation". check for shorts on those especially at the 12v output to the tcon.
        • afdreher
          • May 2020
          • 4
          I just did a visual confirmation of the PS board looking for obvious problems.
          For anyone else with similar problems, neilc6 nailed it: the main logic board was bad. I replaced that board, and now everything works as expected.
          Thanks for all the help!
          • jptferreira
            • Sep 2012
            Mine is not reading correct voltages at the power supply but has the same exact symptoms. I'm reading 19V where it should be 12V at the PS board, is this normal on this system? Do you think it is a PS issue or mainboard?
            When I power it on the first time the power led fades slowly, pressing a second time it blinks 15 times. Can't find any vizio support regarding the blink codes. Thanks for any input!
            • jptferreira
              • Sep 2012
              It was mentioned to replace the U202 eeprom but I'm not sure it will help with this issue because I believe this eeprom is only in case there is audio and no picture
              • neilc6
                • Nov 2015
                • 1550
                Vizios don't have blink codes. 19V is ok. Check for BL-ON not going high. You can also heat up the processor with a hair dryer to confirm before plugging in.
                https://www.badcaps.net/forum/showthread.php?t=76708
                • DemonBG
                  • Mar 2012
                  • 143
                  For what it is worth, i had exactly the same issue on a M60-C3 i picked up cheap.
                  Symptom: standby light comes on, then fades out + optical port lights up. No backlight, no sound. after a few moments the standby light goes off and after pressing power again, the standby light flashes 16 times without powering on.
                  Assessment: Verified PSU was providing 12v and 5V (PSon) but was not delivering 5v to the LED board.
                  Diagnosis - Bad BGA contacts under the chips on the main board. my paricular set showed some heat discoloration on the heat pipe and also around the heatsink itself so clearly this thing had gotten HOT.
                  Repair - I attempted a repair using a heat gun reflow (Without flux) and it got the TV working for about 20 minutes - At least long enough to verify the problem. I am going to try reflowing it again with flux and a IR temp gun to verify i get the solder molten before buying another board (They cost $100+ at the moment). either way i will probably wire in a 12v fan to run on the heatsink to keep temps down going forward.
                  Thanks for the support all.
                  • neilc6
                    • Nov 2015
                    • 1550
                    • econjon
                      • Dec 2021
                      • 3
                      I am in the same boat as afdreher was. Testing exactly as he described. I am a novice so not up to reflow (toaster oven) the existing board. Just want to check that the read on cn101 should be >0 when tv is powered. Found a replacement board for $80 so worth a shot
                      • econjon
                        • Dec 2021
                        • 3
                        Just a bump...question. I baked the main board and the tv now turns on but left half flickering. Anyone else get that/possible solution? Thanks
                        • ossroy
                          • Feb 2019
                          • 18
                          Initially, I had an issue last winter where, when the room was cold, the TV came on but continuosly scrolled through the inputs. Slapping the back of the lower left where the button board and light are would solve things until the room warmed up and things worked fine.
                          Then it started coming "on" but no picture, just backlight. Turning it off and on again fixed things. Then it got worse, where I'd have to cycle power several times to get picture. Then I got the dimming light and sometimes flashing after dimming. Again, cycle power a few times and it would eventually work fine.
                          Now it is dead. I took off the back and started measuring. The only low voltage I get is about 3.3v and 2.something on a few pins. But those voltages make it to the button/IR board, so I'm guessing that's the stand-by voltage and my measurements may be normal for a unit that is off. Not sure where to go from here. I'd like to hope it's the PS because it's probably cheaper than a MB. I saw one YouTube video where the guy just replaced the 4 identical caps at upper-right on PS and fixed it. Based on all those progressing symptoms, any thoughts?
                          Roy
                          • Nick's Tvs
                            • Jan 2014
                            • 621
                            If one side of the screen is not displaying correctly is still the mainboard. You have 2 BGA chips under the heatsink. I recommend you reflow both, if you still have issues you may have to replace or re-ball one of the chips.
                            I have a video on the repair of that exact problem. It's not always a replacement, sometimes you can get away with reflow or re-ball so if it doesn't work you may not have reflowed the board properly and I would suggest you try again.
                            https://youtu.be/G1Rh6Snf94g
                            • Pooshoes
                              • Mar 2022
                              • 9
                              Visio's certainly have issues with the BGA chips, I figure the solder they use grows tin whiskers. Reflow the chip and once it's working turn off "quick start" and the processor won't run hot 100% of the time, just takes longer to boot the panel.
                              • Dani_2024
                                by Dani_2024
                                10-28-2024, 05:06 PM
                              • ygorsan
                                by ygorsan
                                🧩 Problem Summary:
                                • I
                                07-28-2025, 08:34 AM
                              • jb_Bak
                                by jb_Bak
                                CN6401
                                Pin 01 NC
                                Pin 02 NC
                                Pin 03 "BL_ON": 0V
                                Pin 04 "N/C"
                                Pin 05 "STBY 3.3V": 3.5V
                                Pin 06 "GND": N/C
                                Pin 07 "AC_OFF"...
                                09-27-2021, 04:52 PM
                              • JDC
                                (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                by JDC
                                ONN 100012588
                                Issue: No Power, Then Rebooting After Main Board Change
                                Short answer: replace main board and power board
                                Technical answer: replace main board and Q306 & Q307 on power board.
                                Long answer:
                                TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                07-15-2022, 07:39 AM
